Turn signals gone
Old Jun 20, 2004 | 09:14 PM
whazzup's Avatar
Turn signals gone
and emergency flashers not working. Also the cabin air control switch will not redirect the A/C, everything is going thru the defrost vents. I have looked at/checked fuses and such. What else should I suspect?
Old Jun 20, 2004 | 09:32 PM
torquefan's Avatar
The heater control problem seems like a vacuum problem. Check the small plastic vacuum lines that run along the firewall under the hood. Also, the 96's had a problem with engine oil migrating through the vacuum system from the vacuum pump and sometimes ending up in the heater control head. If it gets into a vacuum actuator on the heater box, it will swell and distort the rubber diaphragm.
I think the turn signal problem is a separate issue. Maybe a multifunction switch.
Old Jun 21, 2004 | 06:44 AM
jaconst's Avatar
did you check the flasher unit, square black or aluminum box on your fuse panel, and it has a separate hazard flasher but I had to upgrade to heavy duty flasher, about $10, because my trailer has so many lights.
Good luck
cbrahs
Nov 1, 2011 11:00 AM
big jimmy
Oct 1, 2009 10:00 PM
Sky-dogg
Apr 5, 2004 02:26 PM
HitTheRoad
Jan 20, 2003 10:20 PM
boehunter49
Nov 28, 2002 06:41 PM
