Turbo temp gauge
Old 08-13-2009, 11:51 PM
timmytoo's Avatar
Question Turbo temp gauge
Does anyone have a video or instruction sheet on install of turbo temp probe?
In my Ford, I drilled tapped about 18" beyond the turbo on the exhaust pipe.
Old 08-15-2009, 05:48 PM
Jordan5687's Avatar
Nope, but you're supposed to drill and tap the manifold, need to know the temp before it hits the turbo not after. Run a search on here, you may find pics.
Old 08-15-2009, 06:16 PM
timmytoo's Avatar
turbo temp
Wonder why the Ford would have the sensor after the turbo?
Maybe I was mistaken, been awhile. I'll keep searchin for an answer.
thanks
Old 08-15-2009, 06:18 PM
Jordan5687's Avatar
Well, I know you can measure the temp after the turbo, but before is what you want to measure.
Old 08-15-2009, 09:52 PM
BigDogJeepin's Avatar
Try this:
http://www.dieselmanor.com/diy/CMS3-...ugeinstall.htm
Old 08-15-2009, 10:30 PM
timmytoo's Avatar
great
thanks so much!
Old 08-15-2009, 10:37 PM
graphitecumnz's Avatar
thanks
Well, it is Ford we're talking about....
Heat energy is converted to shaft power by the turbine to drive the compressor therefore, if you sample your exhaust gas temperature post turbo, you are not taking an accurate sample.
Old 08-16-2009, 01:53 AM
phantom 309's Avatar
thats kinda weird on boost, i tapped my into the air manifold
mar67655
03-21-2009 05:35 AM
DennisT
05-11-2007 08:58 PM
turbox2
02-06-2006 07:44 PM
Bad Ramer Jamer
12-01-2005 02:30 PM
firesine
11-24-2005 10:58 AM
Quick Reply: Turbo temp gauge
