turbo spool up
Old May 17, 2005 | 07:13 PM
12vordie's Avatar
turbo spool up
Are there any mods that I can do to get my stock HX35 wih a non-wastegated 16cm exhaust housing to spool up sooner? Right now it spools up at about 1700rpm all the way to 3000rpm, it's a real violent spool up, not a slow steady increase. Is there anything I can do to see the same boost in the lower gears that I see in 5th gear (35psi). I want a little more low end throttle response.
Old May 18, 2005 | 08:45 AM
scarecrow's Avatar
Muted User
good question i would like to know some answers to this one to......
Old May 18, 2005 | 08:51 AM
TxDiesel007's Avatar
Turn up the starwheel
In a diesel fuel is boost, more fuel u burn, the more boost you can make. The simplest thing to do is just get turn up the starwheel, loosen it up, means more smoke and faster spool up, tighten it up and slower spool, less boost. Tinker with it till you are happy, if that dont work, i woud suggest a fuel plate, but bein taht you have done both, now id like to know some answers too... But i would suggest a smaller exhaust housing, it will have to create more backpressure to spool i would imagine... Anyone else have a stab? Plugging the wastegate if it exists, but you are non wastegated.. good one..
Tx
Old May 18, 2005 | 10:35 AM
RowJ's Avatar
Smaller housing for both of you. I have no personal expirience but keep reading threads saying the 14 cm2 works much better, all around, than the 16 cm2.
Scarecrow - your only option for faster spoolup (if you stay with the 16 cm2 housing) is bigger injectors.
RJ
Old May 18, 2005 | 12:44 PM
12vordie's Avatar
I have tried the same setup with the stock exhaust housing with the wastegate disabled, the results were even slower spoolup, that is why I went to the 16cm housing, for less restriction, faster airflow, means a quicker spoolup. I wonder if the answer is some internal mods to the injector pump.
Old May 18, 2005 | 01:58 PM
apwatson50's Avatar
I went from a 16nonw/g to a 12w/g with the w/g disabled and the spool up is way quicker now!! Try and imagine it with a 21cm!!
Old May 18, 2005 | 04:28 PM
12vordie's Avatar
Imagine what with a 21cm housing, you said you gained performance going down in housing size. So I don't see how a 21cm would benefit you. So imagine what with a 21cm housing?
Old May 18, 2005 | 08:32 PM
timeagain's Avatar
I have a hy35, that comes with a 8cm housing I think. whish I had the 16cm that was on my old truck!
Old May 18, 2005 | 10:08 PM
Steve10's Avatar
Scarecrow, I've got the answer for your 24 valve truck...not sure on the 12 valvers. You've probably read about the CaTCHER ECM over on TDR, well I installed mine this weekend...it's insane how quick the boost builds compared to stock. All the low end response you could want, and I'm assuming it only gets better with injectors. If I had a Southbend like you, I'd have the Mach 1.6's on order to go with this ECM.
Old May 19, 2005 | 08:46 AM
CTD NUT's Avatar
Re: turbo spool up
Rjohnson is correct.....You are not moving anywhere near enough fuel to light that 16cm housing soon enough.....the stock 12cm should work well with just #11 plate.....unless you step up to a bigger injector, you need to drop to a smaller housing to gain some spool-up speed.
Smaller exhaust housing=quicker spool-up and higher drive pressures, larger exhaust housing=slower spool-up and lower drive pressures.
Old May 19, 2005 | 08:59 AM
apwatson50's Avatar
Imagine how much spool time there would be with a 21cm, takes half a block!
Old May 19, 2005 | 10:31 AM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
actually its not that bad at all..........
i ran a 21 over my 16 and aside from the initial lag in the intersection which i barely noticed i had very little difference between it and my 16.
it did work well for towing.
Old May 20, 2005 | 10:20 AM
gunracer1's Avatar
we have put two 16cm housings on and both owners hated them and want to pull them off. i run a 14wg housing and it works great all around[but they are expensive]. but i have a couple of 12cm housing that i have port matched, increase the waste gate opening to 7/8" and drilled a 3/4" hole in the divider to bleed off the back 3 cylinders. we are putting one on this weekend and i will tell you the results.
Luvnacumns
29
May 28, 2007 09:47 PM
y22man
May 12, 2005 12:36 PM
RedRotors
Dec 1, 2004 10:00 PM
Zino
Jul 12, 2004 10:27 PM
dakar
Mar 9, 2004 02:33 PM
