Is this from turbo shutter?
Old 08-11-2008, 11:16 PM
samasaurus's Avatar
I was cleaning my air filter and is saw that my fins where damaged. Was wondering if this is from turbo shutter or does this look like something got in there and caused this. Turbo spins fine with no play? please chime in and let me know what you think. Thanks
Attached Thumbnails Is this from turbo shutter?-new-pics-010.jpg   Is this from turbo shutter?-new-pics-011.jpg
Old 08-11-2008, 11:34 PM
trksrfun's Avatar
i dont know if turbo shudder would/could cause that, to me it looks like something got in there and thats what did the damage... check for any opening in your intake system that would let something though that would be my 1st step atleast. good luck hope you find you problem and get it fixed.
josh
Old 08-11-2008, 11:41 PM
braxton357's Avatar
Something(s) got into your turbocharger inlet. I bet it really whistles now...
Old 08-12-2008, 12:00 AM
EBunger's Avatar
It ate somthin fo sho!
Old 08-12-2008, 06:44 AM
HOHN's Avatar
What kind of air filter are you running? If stock, check for leakage. If aftermarket oiled gauze, you've discovered why I recommend against them..
Old 08-12-2008, 07:05 AM
dzlfarmboy's Avatar
Yeah looks like sand or foriegn object nick the fins up some.
Old 08-12-2008, 09:49 PM
duner's Avatar
i'm sure it was shuttering when whatever it was went through the vanes. K&N filter?
Old 08-13-2008, 12:37 AM
Big Blue24's Avatar
That ain't even bad, but if you do have air leaks/foreign debris entering the intake, you better get it stopped before you have real damage.
If it were my truck, I'd run it without a second thought, I've seen much worse hold up for thousands of miles.
Old 08-13-2008, 12:45 PM
samasaurus's Avatar
checked my air filter looks ok. not sure what or when something got in there. I dont know if you can see it in the picture but there is a grove that was created by what ever it was. I found a piece of aluminum inside the air filter last time but didnt take off the intake tube to investigate that must of been what caused it. seems to run Ok.
Old 08-13-2008, 01:23 PM
klx650a2's Avatar
I've got a decent nick in my turbo too from the PO and its still fine... just run it...
Old 08-13-2008, 01:50 PM
nmen's Avatar
If your really concerned about crack initiation and propagation on the wheel you can dismantle a few things and take some time to carefully dress/blend the leading edges; but I'm with klx650a2, just run it.
Old 08-20-2008, 10:38 PM
dieselcamp's Avatar
That is classic damage from dirt, is that filter you have simular to a K & N, if it is throw it in the bush and install a BAHF.
BaconGrainFarms
01-07-2012 05:07 PM
Kenin
07-22-2008 07:52 AM
Hammer Down
02-27-2007 11:29 PM
BLUTIC
18
04-17-2004 06:17 PM
steveb
06-16-2003 01:04 AM
Quick Reply: Is this from turbo shutter?
