turbo question
Old Sep 28, 2005 | 06:25 PM
shoe's Avatar
turbo question
what do I have to do to make a turbo for 2003-2005 Cummins fit on my 2000? what are the differnces?
Old Sep 29, 2005 | 06:46 AM
shoe's Avatar
little help here anyone???????
Old Sep 29, 2005 | 09:26 AM
smokindog's Avatar
Shoe,
Be patient man. It isn't uncommon for certain posts, such as yours, to go upwards of 12 hours without a response. Most of the members here will not respond unless they have the right answer to your question. My attempt to help you is this....
I think you need a different turbine housing. After removing and upgrading the turbo on a friends 04.5 I noticed that the housings themselves are different.
Someone else will chime in here shortly either confirming or denying my thoughts. Just be patient.
Old Sep 29, 2005 | 11:45 AM
CTD NUT's Avatar
Yup, I didn't respond before because I don't know the specifics to this particular swap. FWIW, Smokindog is correct about the turbine housings - they are different.....you would have to run a custom or modified down pipe on your 2nd gen for the 3rd gen turbo to fit. The turbo sits a fair bit lower in the 3rd gen and the down pipes are completely different.
So, why would you want to swap a 3rd gen turbo in anyway?
Old Sep 29, 2005 | 12:46 PM
Gotlift01's Avatar
Yep, I'm pretty sure the housing is different and I know that the down pipe is different as well. And if I remember right ( mental pictures suck ) but I believe the exhaust manifold is different too.........I think
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
