? about tunes with and without timming
i run a diablosport preaditor and the custom puff tunes come with or without timing is timing harder on the motor im not sure how it works.im running without now but if it dont hurt anything ill try the timming ones thanx for the info
HTH
Daniel
It all depends where you want your timing to come from. the prgrammer or module. Most Programmers dont add pressure and need a module to add that, some modules add timing along with the pressure and stacking two timing devices is not advisable. So you can select timing/no-timing from your programmer depending on what module it is being stacked with. If no module being stacked with the programmer then run timing programs. Lastly Always remeber to run gauges (Pryo/Boost at min) when adding any aftermarket fueling.
HTH
Daniel
HTH
Daniel
Some people don't like the timing of a pressure box added with the timing of a programmer. It can get a little loud (timing rattle). Also they make the no timing tunes for people that run NOS. Timing, NOS, and lots of boost are a tad bit hard on the head gasket. Timing makes the motor more efficient though.
thanx for the info i was running the puck but took it off so i guess i can run the timing tunes with no problem.which i did sunday and really liked it just wasnt sure if it was hard on the motor but it sounds fine and all temps do ok if you dont stay in it to long
JaimeG
03-26-2009 06:58 AM
duallydave
04-16-2008 01:15 PM
goodeyesniper75
06-04-2007 08:57 AM
CTDowerTN
05-31-2007 01:20 AM
