TST turbo timer
Old 09-08-2007, 02:07 PM
Townsend600's Avatar
TST turbo timer
Do you have to have the pyro connected on the CR49 in order to use the sool down mode? I already have analog gauges an didn't see the need to have another PYRO.
What is the best setting on the TST for smoking. I can't get this thing to smoke off the line.
Old 09-08-2007, 02:50 PM
purged981's Avatar
On mine I already had a analog pyro gauge so I just connected the tst pyro wires to my existing gauge and it worked fine. No problems after a yr and it reads the same.
Old 09-08-2007, 03:44 PM
isbeinside's Avatar
i get the best smoke out of mine is the 2 or 3-0 in econo mode, smoke clears up on the standard settings.
Old 09-08-2007, 04:51 PM
thanks guys I'm gonna try and hook up my pyro formthe Analog to the TST as well
Old 09-09-2007, 09:52 AM
chrleb1's Avatar
No, you don't need it connected. The TST will shut off two ways. One is EGTs and the other is time. On my TST, I have it shut down at 370* or 1.5 minutes. You should be able to just set a time on yours and go from there.
06RAMCTD
11-06-2009 11:35 AM
CTDPower11
01-23-2007 09:29 AM
TripleBquad
13
11-20-2006 02:59 PM
LinearX
12-04-2005 02:43 PM
Quick Reply: TST turbo timer
