Truck cutting out
Old 04-27-2007, 12:58 PM
Big Daddy Dave's Avatar
Truck cutting out
2001 Dodge 3500 Edge 100hp injectors, edge comp box , smarty, BD turbo,4" exhaust, Dr. Evil Tranny, Afe stage 2 intake,FASS 2, tripple lock torque converter, and a full range of gauges. I've put all this stuff in now when I really get on the pedal it fells like the Torque converter is locking up and realeasing rapidly enough to make the truck shutter. I guess another way to describe it would be as if it were you had a vehicle that was running out of gas but you stayed in the throttle. I know there is fuel pressure because it has never dropped below 13 lbs. Just looking for ideas. Somebody told me it could be a computer issue will re- installing factory settings then putting the smarty and edge back on ??? Any Suggestion would be great
Old 04-27-2007, 01:01 PM
Big Smoky's Avatar
Your VP may be going and causing the truck to shudder. It'll do it even if your fuel pressure is fine.
Old 04-27-2007, 02:46 PM
Ph4tty's Avatar
Check for codes with the smarty
Old 04-27-2007, 03:21 PM
edy
edy's Avatar
my truck does it to after stage 5 jammers install
Old 04-29-2007, 04:24 PM
It's not tripping any codes with the smarty that's why I'm confussed
Old 04-29-2007, 04:30 PM
pokapotato's Avatar
I have a manual torque converter lockup switch on my truck. If I forget and leave it on and start slowing down as if coming into a red light, it will do what you are saying because its locked up of course. Can you control lockup via controller or switch with your trans?
Old 04-29-2007, 04:33 PM
Nope I haven't installed a manual lock up switch yet the truck only does it at about half throttle around 35-45. Do you have instuction for how the wiring goes for a manual lock switch cause I'd love to do that as well
fullthrottle07
06-06-2008 11:50 PM
Kenin
12-25-2006 06:19 PM
vess33
09-19-2006 08:55 PM
kpracing
03-01-2006 06:38 PM
Quick Reply: Truck cutting out
