TRANSMISSION KEEPS BREAKING 3 TIME 11000 MILES
Old 09-29-2003, 05:09 PM
baldeagle's Avatar
MY TRUCK IS A 2003 2500 DIESEL WITH 11,000 MILES AND I'VE HAD IF FOR 5 MO. AT 6000 (8-17-03) MILES THE OVERDRIVE HOUSEING CRACKED, THIS WAS REPLACED., 9-5-03 THE NEW OVERDRIVE HOUSING CRACKED. THIS TIME THE DEALER REPLACED OVERDRIVE AND TRANS, ALSO REPLACED DRIVE SHAFT AS THEY BELEIVED IT WAS OUT OF BALANCE I GOT THE TRUCH BACK ON 9-19-03 (AFTER 14 DAYS IN THE SHOP) ON 9-26-03 THE OVERDRIVE SHAFT SEAL STARTED TO LEAK.TWO OVERDRIVE UNITS ONE TRANS AND NOW A OVERDRIVE LEAK IN SIX WEEK. HAS ANY ONE ELSE HAD THIS PROBLEM. I ALSO HAVE A VIBERATION BETWEEN 75 AND 80 MPH. I BELEIVE SOMETHING IS OUT OF LINE OR OUT OF BALANCE TO CAUSE THESE PROBLEMS. OTHER THAN THAT THE TRUCK RUNS GREAT.
Old 09-29-2003, 07:51 PM
spots's Avatar
Re:TRANSMISSION KEEPS BREAKING 3 TIME 11000 MILES
You don't say whether you have the 47 or 48 tranny. Should fill in your sig and we will know what you drive. Sounds like the original problem was not diag. properly.
Oh BTW typing in caps is YELLING. Yes I am sorta deaf but can read.. Good luck.
(note to the mods: Is this better? thanks)
Old 09-30-2003, 09:22 AM
baldeagle's Avatar
I don't know if its a 47 or 48 its a 3 speed automatic with overdrive. First problem was a cracked overdrive houseing, this was replaced. three weeks later same thing this time the dealer replaced transmission, overdrive section and drive shaft which was out of balance, one week later the output shaft seal on a the new unit has developed a leak.
Ive been told by a few people that it should have a 1/2" spaceer at the center support bracket , so that the angle od drop would be less. the dealer told me this is only needed if the truck is raised. I went under the truck last night and the second section of the drive shaft does not appear to be in line with the first section. It seems to angle off toward the drivers side by about 1/2", I will need to measure to make sure of this, Could this shift to the right and the drop from the center support cause stress on the U-Joint at the connection to the overdrive unit.
Old 09-30-2003, 09:35 AM
Lightman's Avatar
I think 3 times for the same problem qualifies you for the lemon law. Tell them you are fed up and want a new truck... And this time get one with the 48RE automatic...
Old 09-30-2003, 05:12 PM
spots's Avatar
[quote author=Jack Thorpe link=board=20;threadid=20319;start=0#msg190923 date=1064933115]
or better yet, a 6 spd.
[/quote]
What he said....
Congrats on the new truck Jack.
mullishacrew
10-19-2008 03:19 AM
mt250
09-27-2008 11:39 PM
elucho02
08-15-2008 10:31 PM
jcb
07-03-2008 06:57 PM
Hummin Cummins
02-11-2003 12:14 PM
Quick Reply: TRANSMISSION KEEPS BREAKING 3 TIME 11000 MILES
