Transfer case fluid change question...
Old May 19, 2007 | 03:37 PM
Bookmaker's Avatar
Question Transfer case fluid change question...
I want to change the fluid in my transfer case. What size hex wrench is needed for the drain and fill plugs.
Thanks.
Old May 19, 2007 | 05:02 PM
timcasbolt's Avatar
It's a 3/8"
Old May 19, 2007 | 08:11 PM
Bookmaker's Avatar
Thanks much.
I changed out the fluid in my differentials today and used Amsoil Severe Gear 75w110. I think next time I'll get aftermarket diff covers that have drain plugs. I'll be more apt to change it regularly if I can do it quickly. I don't always have a lot of time for this. The oil that came out looked pretty good except that there was black residue on the internals. Is that normal?
I also changed the motor oil today using M1 Turbo Diesel Truck 5w40. Based on recommendations of others here, I had bought a heavier duty drain plug with magnet from Geno's. Turns out that was a good move as the factory drain plug was cracked. That factory drain plug is a POC.
deerefarm06
13
Jul 21, 2008 08:52 AM
030303
Mar 29, 2005 04:16 PM
Jones0027
Oct 29, 2003 01:41 PM
Commatoze
16
Sep 23, 2003 11:15 PM
