Top speed eliminator w/RAD for 00-02 questions
Old 06-20-2009, 11:37 PM
DodgenIt's Avatar
Hey guys… So I had my local diesel shop install a BD top speed eliminator w/ RAD on Friday, and somethings not quite right.
Instructions say that when RAD is turned on by the toggle switch, my instrument cluster will shutdown and check engine light will come on. When switch is turned back off, dash instruments come back on and check engine light goes off.
My problem is that Only the tachometer turns off, and the check engine light doesn’t come on.. until after the switch is turned back off, and the light STAYS on then. even after shut down and restart. I called the shop and they said they hooked it up exactly as it said too but will take a look as soon as I can get it in, which might not be till late next week so I’m asking on here first.
I checked for codes and it’s giving me 1693 and 1694, which is high and low tach voltage which makes sense cause the TSE w/ RAD.
It’s also giving me code 1698. Anyone know that one? I can’t find what it is?
Has anyone else had this problem with this toy??
TIA!
Ian
Old 06-21-2009, 06:11 PM
DodgenIt's Avatar
Secondary question... Im sure the 1694/94 codes will keep poppin up as long as I use the RAD toggle switch... Is it bad to alwayse have codes? Do I need to have them cleared and how would I do that?
Old 06-22-2009, 07:32 PM
DodgenIt's Avatar
Bump.. Anyone have this toy?
Old 06-22-2009, 07:52 PM
Redliner's Avatar
One of my customers has it ill see if i can find out something for ya. Ive never messed with it sorry...
Old 06-22-2009, 11:35 PM
DodgenIt's Avatar
SWEET thanks alot. Im hopin to race this weekend but not if this isnt fixed so any thing will help.
Old 06-23-2009, 06:01 AM
powermad's Avatar
it will take over your computer therefore shutting down your gauge cluster. its supposed to do that your fine. how do you like it i need to get one asap!
Old 06-23-2009, 06:40 AM
I SPEED's Avatar
I have a RAD and it will trip the CEL. It will go out after 5 or 6 key cycles, nothing to worry about.
Old 06-23-2009, 06:43 AM
Redliner's Avatar
Yeah it sets the cel with a few codes, but that what it sopposed to do. Just run it and you should have no problems.
Old 06-23-2009, 11:20 AM
2141pete's Avatar
If it is cutting the defueling it is hooked up properly. My CEL doesnt come on until after the switch is off either and it will take several cycles of the key for it to go away. Your guages dont work because it interupts the signal so it doesnt see a certain boost, RPM, and speed to cut fuel.
Old 06-23-2009, 01:10 PM
powermad's Avatar
does it completely do away with the torque management? and what kind of top speed do you guys see?
Old 06-23-2009, 08:59 PM
DodgenIt's Avatar
My Hell.. I SPEED is that your truck in the youtube link?!? Ive watched that vid a dozen times in the past. That truck is *****!!
Yea I knew it was gonna shut down my insterment cluster, I was curious to the fact that it seems only my tacometer shuts down.
And I was worried about the cel not comin on till after it was off, cause the instructions say cel will only be on while RAD toggle is on, then switch off when the switch is off.
But Its all good with the Cel huh?
One of the codes it gave me was 1698 and I cant find what that is. Anyone know?
Old 06-24-2009, 02:12 AM
powermad's Avatar
mines the black sport with the stack on it! what video are you talking about?
Old 06-24-2009, 02:13 AM
powermad's Avatar
oh nevermind you werent talking about me. lol
Old 06-24-2009, 06:17 AM
I SPEED's Avatar
Yes, that is my truck.
Old 06-24-2009, 07:36 AM
DodgenIt's Avatar
Yea I knew it was gonna shut down my insterment cluster, I was curious to the fact that it seems only my tacometer shuts down. Same with you guys??
Right on way to be speed. That truck is one of my fav's just from that vid.
You Cool Guy!
Quick Reply: Top speed eliminator w/RAD for 00-02 questions
