Tires
Old 02-25-2010, 07:38 PM
fyrfytr68's Avatar
Tires
i have a 1998 3500 dually and cant seem to find the right tires for my truck. Im looking at a tire with an aggressive tread due to driving in farm fields and snow. any ideas?
i also wanted to go up a size but a tire dealer told me that when i put weight on the truck the sidewalls of the dualls will touch and wear faster???
thanks
Old 02-26-2010, 07:33 AM
patdaly's Avatar
Try Cooper Discoverer ST's
Pretty aggressive tread, and not too much in the way of singing.
Love mine, will be replacing them with the same, they are available in 235-85-16.
Old 02-26-2010, 09:58 AM
Midnite's Avatar
What works well in fields is pretty different than what works well in the snow. In the snow you want a tire that has a good cold weather compound and good siping. In a field you want something with good lugs on it, like the BF Goodrich Mud Terrain.
For size, 235-85/R16 is the biggest you can go on a dually without spacers. I've seen duallies that had 255-85/R16s that used spacers, so that might be an option.
Mike
Old 03-03-2010, 12:19 PM
RollsCoal's Avatar
I have the BFG Mud Terrain 255/85R16's and I love the look of them. I have a 1/4 inch spacer, but I think I would be fine without it. I do not haul, but the duals appears to have plenty of room between them.
Old 03-03-2010, 06:05 PM
mr bill's Avatar
If you are looking towards a commercial type aggressive tread check out the Michelin XPS Traction.
Old 03-03-2010, 09:21 PM
grouch's Avatar
thanks
I put some Kelly Springfield Safari STR tires in 265/70R16 on my 2500. It's SRW so watch out for tire scrubbing. Sidewalls aren't as tough as the tread. When they rub together you can eat through a sidewall in short order. They are a fairly aggrassive All Terrain tire but not quite as aggressive as mud terrain.
Old 03-14-2010, 11:50 PM
downlow's Avatar
tires
Id get E rated also...just a better ride when hauling.
chrisminx
07-07-2010 06:48 PM
1320
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
Captain
09-09-2005 12:16 AM
Quick Reply: Tires
