timing cover gasket
Old Feb 22, 2005 | 06:29 PM
Jim5870's Avatar
timing cover gasket
What type of gasket is used on the timing cover, is it cork, rubber, one of those
re-useable o-ringed plastic types?
I recieved my KDP kit from TST today, they give you a tube of RTV to use but I prefer
to use a gasket. My local Cummins dealer wanted $70 for a new one.
What do you folks think, should I get the new gasket or re-use the old one or RTV ?
Cheers, Jim
Old Feb 22, 2005 | 07:26 PM
rebal's Avatar
i payed $65 for the gasket, seal and an o ring for the IJ pump at cummins the gasket is a paper type thats not reusable it glues itself on tight rtv will work but i prefer the gasket as well
Old Feb 22, 2005 | 07:58 PM
BigBully's Avatar
Mine came off without damage to the gasket so i cleaned it up and used Ultra Grey silicone and its fine. I would not be scared to use just Ultra Grey.
Old Feb 26, 2005 | 03:25 PM
SmokinFive9 4x4's Avatar
Available at most auto stores #TCS45902 $35 Felpro.
Old Feb 27, 2005 | 08:02 PM
Monty's Avatar
I should note, while the timing cover is off, its usually a good idea to change the front crankshaft seal as well.
Old Feb 27, 2005 | 11:53 PM
BigBully's Avatar
That was the main reason I one the KDP Fix because the Seal was leaking Bad. I put 2 quarts of Lucas oil stabilizer in a few months ago and it really helped to slow the leak down but I hope now its gone.
Exekiel69
Aug 4, 2008 11:43 PM
mx261
May 24, 2007 06:55 PM
junkhauler
Oct 16, 2006 11:29 PM
macano
May 21, 2006 01:17 AM
Diesel-Dan
May 26, 2004 04:42 PM
