Ticking Fuel Line?
Old 03-14-2007, 01:44 PM
wilderness's Avatar
Ticking Fuel Line?
So I have had white smoke probs. for a while now and have had a ticking noise near my fuel tank as well. This morning I crawled under the truck to locate the tick and felt the fuel line and could feel the pulse/ tick in it. It was ticking the most where the line goes into the tank.
What would cause that? It is a pretty hard tap too, so I imagine that is part of my mpg and smoke prob?
Any suggestions?
Old 03-14-2007, 02:15 PM
waldersha's Avatar
Any suggestions?
Probably your return line. I think the overflow valve has something to do with the pulses on the line. If you get up by the engine you will probably be able to see those lines moving too. Don't really know what effect those would have on your performance. . .
Old 03-14-2007, 03:30 PM
Common's Avatar
Check your fuel filter, you are running lean.
Old 03-14-2007, 04:24 PM
wilderness's Avatar
Actually I'm running ritch, atleast the exhaust smells ritch but no black smoke.
I just replaced my fuel filter a few min. ago and it seemed a little better. What about the screen inside the tank, if it was stopped up would it tick?
My fuel lines are original too, 178k on the clock so I know I need new, but no one around here has the diesel line.
The tick is pretty bad where it goes into the tank @ the connector. It sounds like one of those paint sprayers people use to paint a house with if that helps
I never have probs at start up though, so is that air or the lift pump?
Old 03-14-2007, 06:20 PM
TIMMY22's Avatar
The ticking is excess fuel chattering past the overflow valve. It sounds like it's back near the tank. It's the tight string and two coffee can type thing if you know what I mean.
Old 03-14-2007, 08:11 PM
wilderness's Avatar
That makes since, but to actually feel it all the way back at the opposite end of the fuel line more so than at the overflow does'nt make since.
Even if it's the overflow, does that mean it's bad? And if the overflow is bad does that mean that excess fuel is staying in the pump causing the ritch smell in my exhaust?
I don't totaly understand the concept of the cummins fuel delivery and if I did it might help me pinpoint my issue.
Old 03-14-2007, 08:16 PM
TIMMY22's Avatar
The rich smell in your exhaust is more likely caused by your plate etc. Try using some extra cable ties on the line, It might quiet it down. How old is your overflow valve?
Old 03-14-2007, 08:19 PM
wilderness's Avatar
As old as the truck. I know it needs to be changed. Where is the best place to get one?
Old 03-15-2007, 09:25 AM
Common's Avatar
The tick is somewhat normal...
Every 12v I've heard does it...
Check the OFV - buy a new one from Cummins...
Old 03-15-2007, 10:20 AM
infidel's Avatar
You won't find a better price anywhere
Precision Diesel Injection and Turbo Inc.
Marty Tompkins
888-734-7349
Old 03-15-2007, 10:44 AM
wilderness's Avatar
Marty Tompkins
888-734-7349
I gave Bud a call @ PDI today and ordered the overflow and lift pump. $45 for the overflow now and $95 for the lift pump.
What size studs do I use for that lp?
When replacing the lp, is it similar to a mechanical fuel pump on a gasser with an ecentric, or is it gear driven?
Old 03-15-2007, 11:55 AM
TIMMY22's Avatar
What size studs do I use for that LP
2 @ 8mm x 30mm x 1.25 pitch
2 @ 8mm lockwashers
2 @ 8mm x 1.25 pitch nuts
https://www.dieseltruckresource.com/...ift+pump+studs
Old 03-19-2007, 09:09 PM
wilderness's Avatar
I got my l.p. and overflow in from PDI today (I ordered it on fri. I'm happy) I already put the overflow in tonight and the ticking/ pulsing got much better.
I was compairing the old OV with the new and the old one you could see the ball more through the hole than the new one. It also looked like the spring fit over the ball better on the new one. The truck seemed to run smoother when I drove it around the block.
So now on to the LP, any quick tips?
I think I'm gonna jump on it tomorrow as the rest of my week is gonna be buisy.
Old 03-19-2007, 09:23 PM
TIMMY22's Avatar
It should start better too.
LP....
Use studs
I go at it buy removing the starter (i have long arms). Some folks remove the tire and plastic wheel well.The fittings are awkward to get at to say the least. would be a 15 minute job with the engine out. be patient Careful not to drop plunger into engine when you pull the old unit out. ( just one strait out motion) it's up against the cam so it cant fall out unless you try to take it out on an angle. I put PST on the pipe threads. Not to much fuel will leak out when you disconnect it, it's surprising.
Old 03-19-2007, 09:25 PM
wilderness's Avatar
LP....
Use studs
Thanks, what's the significance of the studs, can't you just bump the motor over and release the pressure off the plunger?
Quick Reply: Ticking Fuel Line?
