What is that tapping??
Old Jul 7, 2008 | 05:54 PM
BMH95's Avatar
I've got a light popping clunking sound, in the front end somewhere, that's getting worse. I cannot find any bushing movement or see any evidence that anything is loose. I've also started feeling a light tapping on the pedals and steering wheel when I'm travelling under 15 mph. Anyone have any thoughts or experience??
Old Jul 7, 2008 | 06:53 PM
madhat's Avatar
Administrator/Jarhead
I kinda have something like the petal feeling that you are talking about... It the go petal kinda vibrates a little more right before a shift? The brake petal has it when I'm stopped...
??? I don't hear any noise, tho.
Old Jul 7, 2008 | 08:03 PM
BMH95's Avatar
Mine aren't while I'm sitting still, rather they are when I'm rolling. It doesn't take a big bump to make it tap, then it is more of a clunky pop. But, when I'm just rolling along coasting, it taps with what feels like every little movement of the truck on the suspension.
Old Jul 7, 2008 | 08:33 PM
cameroneod's Avatar
Sure its in the front end? The clips on the rear leafs come loose and will drive you nuts..
Old Jul 7, 2008 | 08:37 PM
BMH95's Avatar
Clips on rear leafs? I've never heard of those before. What am I looking for?
Old Jul 7, 2008 | 08:44 PM
worldindustries's Avatar
this might help its what I am feeling
https://www.dieseltruckresource.com/...96#post2137196
Old Jul 7, 2008 | 09:29 PM
BigIron70's Avatar
Cummins Guru
I would check for loose shocks bolts or front shock upper bushing worn out or loose.
Old Jul 7, 2008 | 09:39 PM
dslpwr81's Avatar
I hear this all the time. 9 out of 10 times it is the bottom shock mounts are loose. They don't feel loose or look loose, but go under thier and take a big cheater and tighten them up. I would bet this will cure your problem
Old Jul 8, 2008 | 10:33 AM
BMH95's Avatar
I'll take a look at the shock mounts again later on, and see if I find anything.
Old Jul 8, 2008 | 01:58 PM
06MegaCTD's Avatar
yeah i guess i am kinda having the same problem. Can feel the light tapping more on the gas pedal than anything. Only feel it when i am turning left, even just slightly left on the highway. It don't matter the speed, and bumps don't make a difference just does it when normal driving. Can feel it slightly in the steering wheel but most noticable on the gas pedal. Kinda feels like someone is behind it tapping it with the finger while my foot it on it. Does mine sound the same as everyone elses
Old Sep 9, 2008 | 07:51 AM
BMH95's Avatar
Here's a dumb one...
I looked at the shock bolts on the bottom, and I can't figure out how to get a wrench on them??
Old Sep 9, 2008 | 10:12 AM
GreyTD's Avatar
Just use a socket on the bolt head, the nut is held in place with a captive clip.
Old Sep 9, 2008 | 11:22 AM
Socrcrocr1's Avatar
I had the same feeling in my steering wheel and pedals. The dealer replaced the steering shaft and the feelings went away.
96_12V
Feb 29, 2004 04:21 PM
More Power
Jan 23, 2004 06:52 PM
gsdog1
Dec 29, 2003 06:23 PM
MSimmons
Feb 2, 2003 02:09 PM
MARKY MARK
Jan 25, 2003 10:30 AM
