Tac Spedo not Working???
Old Aug 25, 2006 | 10:06 PM
Towrig's Avatar
I was having a problem with my Torq converter not locking up so I cleaned up my TPS and it worked fine for 500 miles. Now my Tac and Spedo is not working at all. I had a shop put in a new Computer at $580 and I am still having the same problem. Any ideas????
Old Aug 26, 2006 | 06:52 AM
plow's Avatar
Could be the ESS.
Old Aug 26, 2006 | 08:27 AM
berner's Avatar
Check your VSS (Vehicle Speed Sensor). It's on the driver's side of tranny tail housing.
Old Aug 27, 2006 | 08:55 AM
Towrig's Avatar
Can those be checked with an OEM metter.
Old Aug 27, 2006 | 11:40 AM
infidel's Avatar
Do you mean an ohm meter? Maybe but I don't know how.
Most often the problem is in the ESS connector up by the thermostat, check and clean it up.
Also check that the gap between the dampener and sensor is about the thickness of a matchbook cover.
If these two things check out I usually replace the ESS without testing it.
Mike T.
May 2, 2008 11:07 PM
jcb
Nov 27, 2005 05:45 PM
strokethis3500
Nov 3, 2005 09:44 AM
strokethis3500
Oct 28, 2005 06:05 PM
hippie
Sep 12, 2003 10:33 PM
