Stock turbo replacement Q's...
Old 11-23-2006, 07:11 PM
NHDiesel's Avatar
Today my turbo decided to call it quits on my way to dinner with the family. I thought my torque converter was finally coming apart from the racket I heard, only to find I now had no power and lots of smoke. I pulled the inlet hose and found the shaft very loose and the vane had ground into the housing. I managed to limp the truck home (only about 6 miles) being careful not to put too much fuel to it coming up our hill. Now I'm in need of a replacement, and I don't know much about turbos for our trucks.
I'm very short on money right now, since I'm still trying to fund the last parts of my transmission replacement/upgrade. I don't pull a lot of weight very often. Performance isn't my #1 priority, but its nice of course. Only mods to the engine have been a Megamouth downpipe (only because the turbo's rear flange had cracked on me last year), and a #10 plate.
I'm looking for the most cost effective replacement. I don't mind a used turbo if its in good condition for the right money. I sure can't afford a new one ($1200 at the *******). I found some remans on ebay for around $400, which is still a bit out of my price range (working part time, low pay, and a family). What is the going rate for a used HX35? HX40? What would be my best option at this point?
With the other problems that have been nickel and dimeing me, if I can't get a turbo for a good price, I'll be forced to find another vehicle and retire this one. I hate to do that, since the engine ran so well, other than the turbo issue. I basically have until the middle of next week to either repair this truck or buy a replacement with the funds I was going to put towards the new clutch and flywheel, since this is my only transportation.
Jim
Old 11-23-2006, 07:29 PM
gman07's Avatar
Used HX35's pop up on the classifieds here and on TDR fairly often, usually for around $300. I don't think you have the fuel for an HX40 or S300 currently; stock will work fine.
Old 11-23-2006, 07:39 PM
TxDiesel007's Avatar
I agree with you on this one here
once a plate goes in as well as other fueling mods, or if you plan to do those, u might wanna step up to the ones stated, but for now a stocker is fine..
Rick
Old 11-23-2006, 08:59 PM
NHDiesel's Avatar
I usually like to upgrade instead of just replacing, but because of my current financial situation, I'll be lucky if I can afford to just replace it with a used stocker. I was eventually hoping to go to a 100 plate after the Spicer conversion, and maybe injectors before too long (they seem to be a very cost effective upgrade from where I am, if I understand correctly), but I'm really having to weigh my options. With a truck this old, at 260K miles, with a bad trans AND needing a turbo, I'm having a very hard time justifying shelling out $1500+ (between completing the trans install and replacing the turbo). I checked the classifieds with only a little possible luck, and there doesn't seem to be much on ebay right now. I'm crossing my fingers, but it doesn't look good for the truck.
Jim
Old 11-23-2006, 09:50 PM
Cummins Freak's Avatar
heres a few
http://www.turbodieselregister.com/c...uery=retrieval
these are from TDR's classifieds keep searching here there is always turbs in the $300.00-$400.00 range
Old 11-23-2006, 09:58 PM
suzuki4life05's Avatar
whats the difference between an hx35 and a stock turbo?
Old 11-23-2006, 10:06 PM
nothing till 01 then i think they went to hy35
Old 11-23-2006, 10:35 PM
Racer9's Avatar
Couple on e-bay;
http://cgi.ebay.com/ebaymotors/cummi...49532100QQrdZ1
http://cgi.ebay.com/ebaymotors/TURBO...61170975QQrdZ1
http://cgi.ebay.com/ebaymotors/Dodge...61209864QQrdZ1
Old 11-23-2006, 10:44 PM
yfz450guy's Avatar
ok, help me understand. whats the difference between hx and hy? i have an 01 so then i have a hy? will a hx work on my rig? thanks for the help.
Old 11-23-2006, 11:46 PM
i think the hy spools faster and has a different housing like a 9cm where as a hx has like a 12 cm i think which spools a little slower but also cools egts a little better
Old 11-24-2006, 12:30 AM
Teddy Bear's Avatar
I see in your sig that your truck has an auto tranny so yes, your truck does have the hy turbo. They have 9cm exhaust housing. The Hx turbo has a 12cm exhaust housing. The hy spools a little faster but doesnt cool quite as well.
Old 11-24-2006, 12:36 AM
Muddin_dude06's Avatar
The HY also has a smaller compressor wheel/housing... BigBlue has some comparison pics in his gallery...
Old 11-24-2006, 01:28 AM
yfz450guy's Avatar
so can i put an hx on my rig?
Old 11-24-2006, 01:37 AM
Teddy Bear's Avatar
Yeah it should bolt right up i think. One advantage of the HX turbos is that you can put larger exhaust housings on them to help control egts a little more.
Old 11-24-2006, 04:40 PM
NHDiesel's Avatar
I pulled my turbo apart today. I think I'm fortunate that the housings aren't damaged as bad as I thought, just some scraping, with very minimal grooving where the impeller rubbed. The impellers also don't seem as bad as I thought they would be. I think I'm going to try one of the $80 rebuild kits off ebay and cross my fingers. If I can make it last until after the trans is in, I'll be able to spend the money on a better turbo (better condition, not necessarily larger).
IF I was to move up to the next level turbo, what would it be? The 2 things that would be nice would be: 1. Faster spooling at my current power level, and 2. Ready for more power when I'm able to do injectors and a different fuel plate, and GSK. I'm just wondering if, while I'll be changing the turbo anyway, if I shouldn't spend the money somewhere other than a stock replacement? I just want to be prepared, and spend the money once, if possible.
Jim
Quick Reply: Stock turbo replacement Q's...
