Stock boost readings-What should they be?
Old Apr 3, 2006 | 09:23 PM
Seeder's Avatar
Just installed a set of Isspro guages on my 06 CTD (trans, pyro and boost). What should the boost be under hard accelerations? My guage will go up to 32-34 lbs then drop down quickly to 24-26 lbs which is what I think it should be. The 32-34 lbs seems kind of high, is this normal or what am I experiencing? The truck runs fine and performs fine. Any info will be appreciated.-Frog
Old Apr 3, 2006 | 10:05 PM
bluebull's Avatar
The spike is about right maybe just a tad high which means it's fueling plenty good. Drops to 26 because there isn't enough load on the engine, you need to tow something uphill with foot on floor or close to it to sustain the 30 psi which the truck is rated at.
Old Apr 3, 2006 | 10:16 PM
HaulinBut's Avatar
Altitude also plays a role in the amount of boost made. How do I know this? I live at 8400 ft. where I show about 29 max, and near sealevel, it more like 31 or 31 1/2. Ohh Yeah....and until I fixed it, everytime I came off the hill, I blew the little rubber hose off of the gauge!
Old Apr 3, 2006 | 10:40 PM
bigwheels94's Avatar
Mine tops out @ 32 psi.As I live @ sea level.
Old Apr 3, 2006 | 10:45 PM
texaspower19's Avatar
i saw about 32psi at stock, know i can almost hit 50
Old Apr 4, 2006 | 12:03 AM
TexasCTD's Avatar
It is my understanding that the 04.5 on up trucks, stock, will peak about 32-34psi but then fall back to about 28 psi sustained because of an electronic wastegate on the turbo. That is what my truck does too.
BossHogg
Mar 12, 2008 04:11 PM
Breck-Ram2500
Jul 31, 2007 05:34 PM
BMH95
24
Jul 5, 2007 10:07 AM
xj_punk
Jul 19, 2005 08:29 AM
