steering gear replacement procedure
Old Feb 19, 2009 | 08:37 PM
bradler's Avatar
Anyone have the service manual procedure for replacing steering gear box? Specificially i need the torque specs for the line connections on top and the three bolts that mount the box to the frame. Thanks!
Old Feb 19, 2009 | 10:15 PM
spitfire9137's Avatar
This is from my 03 manual.
INSTALLATION
(1) Position the steering gear on the frame rail and
install the three mounting bolts (Fig. 4). Tighten the
mounting bolts to 196 N·m (145 ft. lbs.).
(2) Align steering coupler on gear shaft. Install
pinch bolt and tighten to 49 N·m (36 ft. lbs.) torque.
(3) Align and install the pitman arm (Refer to 19 -
STEERING/LINKAGE/PITMAN ARM - INSTALLATION).
(4) Install the washer and retaining nut on the pitman
shaft. Tighten the nut to 305 N·m (225 ft. lbs.).
(5) Connect fluid hoses to steering gear (Refer to
19 - STEERING/PUMP/HOSES - INSTALLATION),
tighten to 31 N·m (23 ft. lbs.).
(6) Add fluid, (Refer to 19 - STEERING/PUMP -
STANDARD PROCEDURE).
(7) Reset the toe and center the steering wheel
(Refer to 2 - SUSPENSION/WHEEL ALIGNMENT -
Old Feb 19, 2009 | 10:50 PM
bradler's Avatar
yes, that's what i needed!
Old Feb 19, 2009 | 10:53 PM
Ace's Avatar
Ace
And splice a Magnefine filter into the hydra-boost return line while you're at it. Maybe this one will last a little longer.
1970dodge
Feb 13, 2009 08:38 PM
dixiedog
Jul 29, 2007 07:03 PM
docram
Nov 7, 2006 11:16 PM
Tommy93w350
Jul 7, 2006 01:35 PM
wood_n_soldier
Jun 16, 2004 06:15 PM
