Starter fuse blows when starting.
Old 07-31-2010, 09:39 AM
nubbs00's Avatar
About once a week when I try to start my truck I hear a "Click" then nothing. All the electronics work but the starter. I check the 20amp fuse and its blown. I replace the fuse and it works for about a week or a couple of days then "Click". I keep a box of fuses in the fuse box. It doesn't mater what the weather is like or if its the first start of the day or the 5th. It happens randomly. Any buddy have any idea what might be causing this?
Old 07-31-2010, 09:45 AM
Copenhagenjunkie's Avatar
I would say the starter contacts are worn out.
Old 07-31-2010, 10:15 AM
DieselNomad's Avatar
contacts or the heavy red wire at the starter may be bare somewere, i just had this issue on inlaws truck.replaced starter,all was good for a while then back to blowing fuses,checked for bare wires and there it was.tape shrink wrap issue solved.hope this helps.
Old 07-31-2010, 11:28 AM
nubbs00's Avatar
Thanks for the replies. I will be checking the connectons this afternoon. We have a good shop that can rebuild the starter if needed. The truck has 180k on the origanal one.
Old 07-31-2010, 03:13 PM
boughtadodge's Avatar
put a circuit breaker in place of the fuse.
Old 07-31-2010, 08:41 PM
Junk Man's Avatar
You likely don't need to rebuild, only replace the solenoid contacts. Rebuilds around here are $80-100. Contacts are $35 for the big thick ones.
FMB
11-14-2010 09:09 PM
schu
11-07-2006 06:51 PM
CRE2004
10-21-2005 08:05 PM
BigBlue
11-18-2003 03:28 PM
Smokee
04-05-2003 03:45 PM
Quick Reply: Starter fuse blows when starting.
