Smoking, Rough Idling, Missing
Old 09-24-2008, 07:02 PM
SWATPARAMEDIC's Avatar
2001 24 Valve, 220,000 Miles. My truck suddnely began idiling rough and putting out black smoke. Put some additive in it and filled up and about 5 minutes later started knocking, running real rough, and lots of white smoke. Replaced # 2 and 3 injectors which helped a lot, but still puts out some white smoke and smells like fuel. Also had some fuel under the valve cover, going to change the oil shortly. ANy other ideas to try or more injectors going out? Injector and lift pumps have been replaced. Thanks in advance.
Old 09-24-2008, 07:32 PM
dozer12216's Avatar
Check for codes. Have all injectors been replaced??? Next sounds like VP44 may be going.
Old 09-25-2008, 02:17 AM
It's not throwing any codes. Only two so far, but it's idling a little better, still smoking. I replaced it about a year and a half ago. There is place here in town that carries and rebuilds pumps, turbos, etc and carries injectors. He said in their experience that the injectors start going at 200,000 miles. I've got 220 and started wondering if maybe they all are starting to go.
Tyler
01-13-2012 01:34 PM
drew03
08-19-2008 10:12 AM
scottmn1
07-28-2007 05:49 PM
8mpg
17
04-24-2006 10:05 PM
silverbullet02
09-07-2005 04:49 PM
Quick Reply: Smoking, Rough Idling, Missing
