Small turbo diesel for a small vehicle
Old 01-09-2012, 01:08 AM
CruisingRam's Avatar
I am thinking of picking up a older jeep with no power train. It came with a gas four banger. I would like to go diesel. I would like a small diesel with close to the stock HP of the four banger. About 60hp.
Any suggestions that are reasonably obtainable?
Old 01-09-2012, 05:26 AM
rich's Avatar
kubota or perkins maybe
Old 01-09-2012, 08:20 AM
MTC
MTC's Avatar
Cummins 4bt
Old 01-09-2012, 08:39 AM
Purplezr2's Avatar
Kubota D902 with a Turbo and injection pump work will make 50HP 80 ft-lbs
Kubota D1105 should be able make the 60HP you are looking for.
Old 01-09-2012, 09:23 AM
Circle B's Avatar
Adapting small turbo
I have a '93 project Jeep I'd was thinking of doing the same thing to. Several questions come to mind; 1) Will the stock tranny hold up to the diesel torque?; 2) Will the rpm range be compatible?; and, 3) where would one find the engine to tranny adapter plates?
Old 01-09-2012, 01:33 PM
Hodge's Avatar
You should surf the jeep forums- there are lots of guys who have put 4bt cummins engines in jeeps. I doubt that the stock manual will hold up- that will depend a lot on what year jeep, and what transmission, you are mating up to. The old T-19 would, a peugeot 5 speed won't.
Because the 4bt was designed for trucks, I would imagine that it's rpm range would be more suited, than a tractor engine.
Old 01-09-2012, 07:57 PM
rich's Avatar
i run those kubota motors full throttle in the bobcats and they have a good rpm range. 4bt is gonna be costly and probably hard to find since they are the new hot conversion motor thing now. As far as an adapter plate you can make your own or have it made by a welding shop.
Old 01-09-2012, 08:22 PM
ccfd176's Avatar
I've got a 1994 wrangler with a thermoking (yanmar) 4cyl with a jetta turbo and intercooler. Top speed 65 but slows on long hills. It gets about 30mpg.
Old 01-09-2012, 11:46 PM
Any recommendations for which Jeep site? How much does a 4BT weigh?
Old 01-10-2012, 07:41 AM
jstone44720's Avatar
There are bolt in kits to put jetta diesels in newer jeeps. You may be able to find one for your application. I like them because they are very light and can make 200 HP easy.
Old 01-10-2012, 05:23 PM
Any links on line where I can see this?
Old 01-10-2012, 10:30 PM
SIXSLUG's Avatar
A used 240 Mercedes is a stout running diesel, reasonably light and can run on just about anything. A turbo can be easily adapted.
Its a 4 cylinder 2.4 l.
The 3.0 is a 5 cylinder and was adapted for a turbo. Its the MB engine the Cummins 5.9 24V is modeled after and is also a good candidate for your project.
Both reasonably priced, well made and readily availabe. Many times the car body is shot because of age and have under 100K miles.
Old 01-11-2012, 12:28 AM
Ooo- that is a very good idea- Hawaii has a huge amount of Mercedes diesel cars- might be able to find one local- but ****, do I adapt it to the stock Jeep trans or use a Mercedes trans- hard to find a manual?
Old 01-11-2012, 12:37 AM
westcoaster's Avatar
Not really "easly obtainable" but a neat project regardless...
http://www.hpamotorsport.com/tdijeep.htm
Old 01-11-2012, 12:46 AM
Wow- that would be totally worth it!
Quick Reply: Small turbo diesel for a small vehicle
