What size EDM'S
Old Aug 15, 2005 | 08:47 PM
More Power's Avatar
What size EDM'S
I have a 99 24valve 5 speed that just sled pulls and i am running a stock cam and pump with a edge drag comp and good sbc twin disc, with a sledpuller 66 turbo from htt. What is the biggest edm you would run with this set up. The head on this truck is fireringed. The truck now has between 175 and 200 hp extrude honed injectors from eep.
Old Aug 15, 2005 | 11:20 PM
dodgediesel4x4's Avatar
Do you use this truck as a daily driver? If so, then mach 6's are the biggest you can go and still drive it to work and back. Anything bigger than 6's are not recommended for street use.
Old Aug 16, 2005 | 09:22 AM
turbo thom's Avatar
He said he only sled pulls.
Old Aug 16, 2005 | 09:51 AM
RowJ's Avatar
I would also say Mach 6's. I believe the MAch 7's are twins only.
Saw a set of 6's in the Classifieds for sale...see the add for B-1 twins, if interested.
RJ
Old Aug 16, 2005 | 02:13 PM
More Power's Avatar
Thanks guys. I called Power by Poole today and order a set of mach 6's should be plenty of fuel if i have plenty of turbo. I will let you know how hot it gets.
More Power
Mar 2, 2004 01:55 PM
Idaho CTD
53
Oct 7, 2003 01:12 AM
pro puller
13
Apr 18, 2003 09:39 PM
hellotbone
19
Mar 7, 2003 02:01 PM
KatDiesel
69
Feb 23, 2003 08:01 PM
