Shaking of truck
Old Jan 15, 2008 | 10:29 PM
bootsdodgejn's Avatar
Shaking of truck
Ok well i thought it was the death wobble, but shocks are new,trac bar new, every thing eles in the front end is good and tight..
It still shake when im acceleratin and above 50
alson dosnt seem to happen till 30min into drive
I was told its either the trans or t-case
Any idea guys
Old Jan 15, 2008 | 10:45 PM
skynyrd's Avatar
could be the tires. check the pressure and make sure its correct and try rotating them. they heat up after a while. also check the color and smell of your tranny fluid
Old Jan 15, 2008 | 11:03 PM
well the tires it was doin it before i got these new ones and still doin it after
Pressure ill check
what should be the color and smell be
Old Jan 15, 2008 | 11:56 PM
skynyrd's Avatar
should be red not brown and you can smell it if it is burnt
Old Jan 16, 2008 | 02:19 AM
getblown5.9's Avatar
if it only happens under acceleration, and not just cruising above 50mph then im gonna say its your torque converter shuddering
Old Jan 16, 2008 | 08:50 AM
yea the shakes vary from being light to headach shake.
Im goin to check the trans so ill let u know
Old Jan 16, 2008 | 09:55 AM
ok the trans fluid it red with no real smell
Old Feb 13, 2008 | 12:59 AM
Crabjoe's Avatar
Could be a U joint too.
Old Feb 13, 2008 | 02:55 PM
smokin95's Avatar
or a carrier bearing... mine did this
Old Mar 5, 2008 | 10:15 PM
taken5875's Avatar
my money is with getblown
Old Mar 5, 2008 | 10:59 PM
Well i got the shaking. new trans and tq
Old Mar 5, 2008 | 11:07 PM
skynyrd's Avatar
boots you are saying its still shaking?? you might just have to take me for a ride and make it do it.
Old Mar 5, 2008 | 11:26 PM
oh opps edit.. i meant to say I GOT THE SHAKING TAKEN CARE OF sry for the mix up
It drive so much better now..even with level 3 smarty
yfz431
Dec 16, 2007 04:51 PM
Jmac
16
May 24, 2006 05:46 PM
heavyboostin
Jan 13, 2005 06:55 AM
shaft
Jan 25, 2004 01:35 PM
