S.O to H.O
S.O to H.O
I have a friend with an 03 S.O he tells me that he went to the dealer and changed his truck to a H.O just by going back and forth with the Key from run to stop 4 times. Then The display panel said change H.O. Is this true?
Just kidding, I have no idea if that is true; it would be rather crazy if it were though!
Why would you want to be a HO. SO nice to be special. SO trucks are a little slower and are virtually powerless, like mine and alot of the others on the ultimate HP and 1/4 mile time lists.
ks
ks
My SO was the best truck I have had, I wish I still had it. I dont see how your friend could turn his SO into an HO unless turning the key also changed the oil gallery cooled pistons LOL. But as far as the higher horsepower goes it is just changing the ECM program.
Any of the downloader and boxes that have 9 settings that you can't use ....just set to one higher than your buddies truck. I could run the TST on 8/7 virtually stock when none of the HO's could run 7/5 without draining the rail....stock. ks
PT Barnum
L8r,..............dogger
Ok but think about this. If you have a H.O with 305 hp and add a Box that gives you 75hp your truck goes to 380hp. If you have the S.O and add the same box your truck would go to 380hp also. So in theory it should work. So one of you with a S.O go down and turn your key 4 times without starting and see if it works.
[I have a friend with an 03 S.O he tells me that he went to the dealer and changed his truck to a H.O just by going back and forth with the Key from run to stop 4 times. Then The display panel said change H.O. Is this true
If it doesnt work repeat until it does.
haha what a crock of $h!t.
I wouldnt trust your buddy anymore since he's obviously a liar and you shouldnt hang with liars.
That's awesome that you can magically change a AAM 10.5 to a AAM 11.5 rear diff and a 47re- 48re not to mention all the different hard engine parts like oil injection for free.
I am glad you are getting a good laugh at my expense. BUT none of you own a S.O!!!! So would somebody with an S.O try this!!! And if my buddy is pulling my leg it doesn't make him a liar it makes him a ball buster. Their is a difference
Dave, there's no magical way to change from 250hp to 305hp plain and simple. If he wants to believe that then let him. Have him do his magic and then line the trucks up and see who's got more power. My SO was a slug without power adders. Heck, My friend's 01 was faster than my 03 SO was until I started BOMBing it.
Honestly, you must be joking, seeing what kind of reaction you can get, whatever. Something I'd expect from BigDan
Why would *anyone* spend the $$$ to get a HO if it was that easy to "upgrade" your SO?
There's a reason there was no automatic behind the HO motors until the 48RE came out. The 47RE couldn't handle it. If it was as easy to "power up" as you say it is, there would likely be lots of transmission failures.
I'll buy his dyno time if he can prove it. A run before the magic key cycles, during the key cycles, and after. Continuous video, no boxes or downloaders, ecm swaps, foolers, propane, nitrous, etc. Any splicing of the video or starts/stops and I won't pay.
And by the way, if you put a 60hp box on my truck, the rwhp goes from about 250 to 310.
Put a 60hp box on an SO and you'll go from 200 to 260.
When making max power with multiple boxes and supporting mods, both engines will make about the same overall hp.
Technically I guess you could say the SO's respond better to power adders.
