rig wheel questions.anyone here mill them?
Old 12-31-2009, 07:33 PM
Lucas1's Avatar
ok was looking for a set of 22.5" wheels
A friend of mine has a pile of 24.5" alluminum wheels laying around-
FOR FREE
I cant find a low profile tire for a 24.5" wheel thats smaller than a 41"
Anyone here do machining that has cut rig wheels down to a 24"
iam thinking of going this route and runnin a automotive tire.
What would be the cost?
I also think it defeats ther purpose of even bolting the rig wheels up .i wanted to extend tire life/never buy another set.
The other question is there a difference betweem front and rear wheels?He has them on his cab over logging truck and says they are universal...just flip them around for front/rear??is he right?
anyone want to trade for 22.5"
want to run a 255 tire......anything up to a 38" diameter
Old 01-01-2010, 06:09 PM
Montana2x2's Avatar
Yep rims are the same, inner and outer. As far as I know there are 2 types of rim, one is centered by the lugs, an inner and outer lug nut. The outer nut is 1 1/2" and the inner nut is 13/16" square (I think). The other type of wheel centers on the hub and uses a single flanged nut to hold both the inner and outer wheel on. I think it's an 1 5/16" No the 2 types of wheel do not interchange. Around here 22.5's are much more common than 24.5's as most over the road trucks run them these days. We had a 24.5" wheel break and a steel reconditioned wheel was only about $50 so if you reallllly want 22.5's they are not too expensive unless you want aluminium. Good luck.
Old 01-01-2010, 06:58 PM
Lucas1's Avatar
i want alluminum so to cut the weight down......idealy i would like it to not weigh much more than a set of 36" tires on a factory steel wheel.Keep the reciprocating mass down.
ad removed
mulisha
33
03-10-2009 07:51 PM
Hawthorne
12-11-2007 07:37 PM
Dufrain
01-06-2005 12:03 AM
gunracer1
09-25-2004 02:52 PM
Stamey
06-02-2004 07:24 AM
Quick Reply: rig wheel questions.anyone here mill them?
