Reverse / back up lights stay on
Old 02-15-2010, 11:24 PM
nvr-enuf's Avatar
I have a weird situation occuring. The trucks back up lights stay on while turned off. The truck does not have the stock lights due to the flat bed and has LEDs therefore it can stay on overnight and not drain the battery but I would like to get it fixed. I even have a back up camera that goes on with the reverse light / back up light power therefore I am pretty sure the truck simply thinks it is in reverse.
Any help would be appreciated.
SAS
Old 02-16-2010, 07:06 AM
BigDiesels's Avatar
May not apply to you, but I added backup lights and used a relay for the power feed, triggered off the trailer plug. The relay failed (I think water got in and seized the contacts closed) and the lights would stay on even with the key off (because of the direct feed from the battery).
Old 02-16-2010, 12:58 PM
nvr-enuf's Avatar
Good point, thanks - I will try to see if the LEDs have a relay, try trouble shooting.
SAS
freshmeat
07-12-2018 09:21 PM
cjs1450
01-13-2014 03:57 AM
Insayn
01-05-2012 12:29 AM
MrTwister
01-24-2011 09:23 AM
Jim Dynomite
06-06-2006 09:57 PM
Quick Reply: Reverse / back up lights stay on
