rear main seal
Old Jan 28, 2008 | 01:09 AM
SmokemS's Avatar
rear main seal
ok guys
my ol girl like to mark her territory everywhere we go...to be honest i hate it cause i usually have to clean up everywhere i go....so my question is ....do the cummins use what they call a rope seal for my rear main seal?.....if not what does it use and how much is the seal itself...cause i have a guy that will do it for me ...and maybe you can help me out by telling me any little tricks that will help my 50/50 chance of it working
thanks
smokems
Old Jan 28, 2008 | 06:14 AM
JD730's Avatar
I would expect to pay at least $50 from cummins for that seal, I think the last one I bought was $42, but that was a couple of years ago.
The seal itself is pretty big, one piece, Teflon lip seal. I find the easiest way to change on is get the trans out of the way, from the clutch and flywheel. Carefully drill to holes and screw in 2 sheet metal screws and pry the old seal out. Clean the area up, brake clean works best, make sure the crankshaft is clean, dry and free of oil, these seals MUST be installed dry. Check the crank for wear grooves where the seal rides, if they are too deep you'll have to use a different seal with a repair sleeve, that will require a special installer.
Take the new seal, I usually put just a light film of RTV on the outside. The new seal come with everything needed to install it. I usually tap around the installer tool with a hammer and pull the plastic sleeve out of and finish pushing it in when the seal is sitting on the crank. Reinstall everything you took off.
Old Jan 28, 2008 | 11:21 AM
SmokemS's Avatar
mike have you had good luck with this ...my buddy never put one in on the old cummins....so i like someone that knows exactly what there doing
Old Jan 28, 2008 | 11:31 AM
Micaiahfied's Avatar
it's really nothing special, just the pain of removing the tranny. Why would you say the chances are only 50/50 of it working?
Old Jan 28, 2008 | 01:35 PM
Fred Swanson's Avatar
it's a very easy fix, once you have the trans out of the way.
Old Jan 28, 2008 | 02:22 PM
woodrat's Avatar
I had mine replaced when the tranny shop put the NV in. It still drips a little back there.... grrr!
Old Jan 28, 2008 | 09:31 PM
rlyons's Avatar
I would pull the seal adapter out and replace the gaskets behind it while you are in there. It is easier to put the seal in the adapter while it is out on the bench also. Make sure you take alook at the cam plug also and make sure it is dry and not leaking. The rear main seal also has to be put in dry or it will leak.
ted_pulliam
Aug 4, 2010 11:33 AM
bnold
Jul 7, 2007 06:18 PM
chaikwa
Mar 24, 2004 09:23 PM
okcummins
Dec 21, 2003 07:45 PM
Mostwanted
Sep 17, 2003 06:55 AM
