Rear Driveshaft Options/Questions
Old 02-04-2010, 04:14 PM
D45
D45's Avatar
I know atleast one of the factory sealed ujoints in my truck's rear driveshaft needs replacing....and I do not want to replace just one and have a band-aid fix
My truck is a long bed truck, with a 4.5" lift and 37" tires
What is my best option?
1) Install all new greaseable ujoints and replace the carrier bearing with a new unit
OR
2) Replace the current setup with a one piece rear driveshaft
I found a heavy duty carrier bearing, which I believe is made for the C&C 4500/5500 series trucks. Spicer #210391-1x
I also read there's a heavy-duty urethane-cored carrier bearing available to fit from the OTR sector... they run ~$180 (not sure of the part #).
I read somewhere that lifted trucks won't benefit ( too much bind ) from the one peice shaft, hard to get balanced and stay balanced.
I heard the one piece puts the more stress on the trans case and differential than on u joints.
Any input or suggestions?
zchornyak
12-19-2007 01:29 PM
FDPOWER
02-15-2007 11:53 PM
TxDiesel007
12-10-2006 08:04 AM
GO 4LO
0
10-25-2003 09:52 AM
Quick Reply: Rear Driveshaft Options/Questions
