Rear axel Leak
Old Nov 20, 2002 | 09:55 PM
yz's Avatar
yz
Rear axel Leak
Well i was at work today and was admiring my truck whjen i looked at the rear axel and noticed a leak coming from the from of the rear axel. I thought i had heard of this being a problem before. So is this going to be a major pain in the @#* like I think it will be. Hopfully i am wrong. I guess I should go by a service manual, I have been planing on getting one but money is tight. Well this is just a great time . Really I should not be about it but if I was not then i would be :'( . Oh well. life goes on -Anthony
Old Nov 21, 2002 | 08:20 AM
dodgeman01's Avatar
Re:Rear axel Leak
Is the leak at the end of the axle or at the pumpkin. Mine leaked out of the driverside of the axle. I just tightend the bolts down a little and it went away.<br>Aaron
Old Nov 21, 2002 | 08:33 AM
yz's Avatar
yz
Re:Rear axel Leak
It's at the front of the Pumpkin :'( . I have never had to replace a seal like before. Should be intresting. -Anthony
Old Nov 21, 2002 | 07:55 PM
yz's Avatar
yz
Re:Rear axel Leak
So can anyone answer my question. Thanks -Anthony
Old Nov 21, 2002 | 08:18 PM
Jbolt001's Avatar
Re:Rear axel Leak
It's not really hard to do. Try replacing all the bearings in the rear diff some time <br><br>To torque the nut on the pinion shaft properly you need a tool to hold the yoke. I made one by burning a hole in a piece of channel iron. I have been told you can do it with the tires on the ground and the parking brake set but I was sure I would screw some thing up so I made a tool;D<br><br>Aint maintenance fun <br><br>Good luck
Old Nov 21, 2002 | 10:48 PM
yz's Avatar
yz
Re:Rear axel Leak
It drives me nuts to see that i am so bad at messing up spelling. Axel. WHat i ment to put was axle. Sorry that just drives my nuts. And i do it all the time. <br><br>Jbolt thanks for your input. That was what i was looking for. I love to do regular maintenance but maintenance that is unexpected and not at the best of time. So what is the torque on that pinion shaft nut? Thanks -Anthony
Old Nov 22, 2002 | 12:32 AM
Jbolt001's Avatar
Re:Rear axel Leak
My manual shows 250-300lbs for the Dana 60/70
Old Nov 22, 2002 | 08:38 AM
yz's Avatar
yz
Re:Rear axel Leak
ok thanks -Anthony
Old Nov 22, 2002 | 12:31 PM
yz's Avatar
yz
Re:Rear axel Leak
one more thing. What size is that nut? I want to make sure i have the right size socket before I go pulling it apart : -Anthony
Old Nov 24, 2002 | 04:55 PM
JFellman's Avatar
Re:Rear axel Leak
Just did mine yesterday at a friends shop...he didn't appreciate me dripping gear oil all over his nice driveway
He took a brand new 1 7/8 socket from Sears and put it in a drill press and ground on it with a grinder until it fit inside the yoke...I think he said he took over .020&quot; off. We torqued it with the parking brake on to over 200 ft-lb with a BIG torque wrench. He said just get it &quot;RFT&quot; .... ;D hth
Just noticed that mine is a Dana 80...you might want to measure the yoke nut on yours...might be a little smaller
Old Nov 24, 2002 | 06:05 PM
yz's Avatar
yz
Re:Rear axel Leak
Thanks for the info. John. I Have been keeping on eye on it and it seems to have stopped. I don't know why but it has just stopped. But I will replace it anyway, It will cause more trouble down the road. So thanks again. -Anthony
Old Nov 25, 2002 | 11:36 AM
turbospl311's Avatar
Re:Rear axel Leak (be cautious)
I just got my truck back after having a axle seal (driver's side) start leaking. I took it ot the Dodge dealer as they were having a special on rear end work. I was qouted $125 out the door to replace the seal. they opened it up and founf the axle had been grooved. That was another $125 for a sleeve and install. Picked up the truck and on the way home (7 miles) a squeek developed. Drove to the store an hour later and teh bearing seized on that side.<br><br>Called the dealer and they sent a tow truck. Apparently the mechanic had not pre-greased the bearing and it seized and fused itself to the housing. They put in a whole new third member ($4200) and 4 new tires for my trouble. They did have the truck for 3 weeks.<br><br>I would change the seal out but make sure to pre-grease the bearings!!!<br><br>Don M.<br>97 2500 CTD #6 plate, straight exhaust, cold air intake, Brand New Rear end!
Old Nov 25, 2002 | 06:04 PM
yz's Avatar
yz
Re:Rear axel Leak
3 weeks that blows. thanks for the advise. -Anthony
quadman20
Nov 14, 2009 06:37 PM
3500eh
Jul 29, 2008 08:58 PM
sullivad
13
Dec 18, 2006 08:47 AM
JImbo1
Apr 9, 2003 07:46 AM
yomitch
Nov 22, 2002 12:11 AM
