questions on tranny mod...
Old Apr 26, 2005 | 08:04 PM
pmtg's Avatar
looking into a TC and VB for the A518.
questions that pertain to a lock-up switch for the TC:
1) how easy is it to run a switch? as far as wiring it up. seems like a simple computer control and easy wiring.
2) if i did this, i would want to protect the switch from other drivers that do not know how to operate it. are the TC's that are designed to lock-up with a switch allowed to run continously without lock-up (for the sake of someone else driving the truck and not using the switch)?
3) is it really worth it? are there mileage increases and/or performance increases that would offset the price?
4) what companies offer a lock-up TC for this application?
5) who is running a setup like this?
thank you in advance,
Pat
Old Apr 26, 2005 | 08:08 PM
Den's Avatar
Den
I don't think you can modify a 518 to use a lock-up style converter. You would need to upgrade to one of the 94+ transmissions.
Den
Old Apr 27, 2005 | 07:30 AM
jonmurr's Avatar
Den is right. There is a passage for lockup fluid in the case in between the V/B and the pump you need. If you want lockup, you need a complete 94-96 47RH tranny. Also , If you are a 4WD truck,
you may have transfer case issues, maybe some one can chime in on that one, the part #'s for the output shafts are different, doesn't mean they wouldn't work though.
Jon
Old Apr 28, 2005 | 08:11 AM
apwatson50's Avatar
What is L/U?
Old Apr 28, 2005 | 08:32 AM
Mcmopar's Avatar
lock up
Old Apr 28, 2005 | 08:43 AM
apwatson50's Avatar
So you can ad a L/U valve body and L/U input shaft in to the 727 tranny with the O/D?
Where do you get these parts from?
Aaron
Old Apr 28, 2005 | 09:06 AM
Mcmopar's Avatar
My best guess would be a junk yard??
Old Apr 28, 2005 | 09:13 AM
apwatson50's Avatar
These parts would have to be aftermarket because the 727 never had a L/U torque converter. Unless these parts from a 94 and newer tranny would fit in the older one, but I seriously doubt it.
Old Apr 28, 2005 | 10:05 AM
Mcmopar's Avatar
What that guy was refering to was a retro fit of the 94 and up stuff. I would just go get a 94-95 tranny-the 47RH and bolt it in.
Old Apr 28, 2005 | 10:11 AM
apwatson50's Avatar
Is there an adaptor to bolt the 205 T/C to the 47RH?
Old Apr 28, 2005 | 10:50 AM
Mcmopar's Avatar
I am not positive, do a search of the internet, I think there is a company that does-I was looking into this also at one point in time.
Old Apr 28, 2005 | 12:07 PM
Mcmopar's Avatar
TXS,
what 48RE parts do you use? Where do you get them?
Old Apr 28, 2005 | 01:40 PM
apwatson50's Avatar
What is the tranny called in a 92 w/O/D. I thought the 91.5-93s with the O/D were just a 727 with an overdrive bolted on the back?
