Question about Boost Regulator
Old Aug 23, 2005 | 01:03 PM
mike6256's Avatar
Few questions about this Boost Regulator
How does it work, where does it go and how much more boost will I see?
Last is it worth it? I currently have Superchips programming, but still need to pull 10,000lbs safely without eating the trans.
Old Aug 23, 2005 | 01:52 PM
ramtd02's Avatar
no its not worth it!!! Just go too your local hardware store and pick up a 7/32 turnbuckle for 2 bucks....then install it on the wastegate (going under the truck makes this a 30 second job). It closes the wastegate totally, but you are not pushing enough fuel too hurt you.
Old Aug 23, 2005 | 02:09 PM
67HotRod's Avatar
Well, you have a superchips, which doesn't have boost fooler, last I checked. So the turn buckle or the j-hook is not going to buy you much. I ordered one this morning, and am buying either an edge ez or comp very shortly.
Old Aug 23, 2005 | 03:05 PM
Bob Wagner's Avatar
this one costs 50% less
Old Aug 23, 2005 | 03:18 PM
67HotRod's Avatar
Bob I though about buying that one, but I like the adjustability factor with bully dog. To each his own.
But hey, several option to choose from. COOL!
Old Aug 23, 2005 | 06:22 PM
TRCM's Avatar
OK, so what does this do ??
Does it basically lock the wastegate closed ??
And will it give me problems with a stock turbo, #11 (soon to be #10) plate, and 3gsk, plus 4" exh & BHAF ?
or would it just be easier to plug the line to the wastegate ?
I think I am losing too much boost to the wastegate for the fuel right now.
johnr9q
24
Mar 17, 2015 07:03 AM
pmpislander
Feb 8, 2011 10:08 AM
freeloader
Mar 28, 2003 09:00 PM
hellotbone
Oct 9, 2002 02:20 PM
