Where to put a fuel pressure gauge?
Old 06-02-2005, 05:58 PM
Bobcat698's Avatar
Question Where to put a fuel pressure gauge?
I am currently working on a 2001 Cummins and have installed the boost, pyro and trans temp gauges on the pillar.
Does anyone have any suggestions on where to put this gauge?
Thanks!
Old 06-02-2005, 06:00 PM
phox_mulder's Avatar
Many mount it below the dash, on the tranny hump, or on the dash.
It's not one you have to watch constantly, just a check every now and then.
Mine is in the pillar, bottom cup, with the EGT mounted on the dash next to it.
Figure these are the two most important ones, so they are next to each other.
Pics in gallery.
phox
Old 06-02-2005, 07:23 PM
pmtg's Avatar
first off, you have a 12 valve so i wouldnt worry about it.
if you have to have it, do a steering column mount.
Pat
Old 06-02-2005, 08:22 PM
mkrenn's Avatar
This is only if yours is a 12 valve!
Old 06-02-2005, 08:34 PM
pmtg's Avatar
disregard my last post. i was looking at your truck, not the 2001 you are working on. brainfart! nice catch mkrenn!
Pat
Old 06-02-2005, 11:11 PM
Walt L's Avatar
I took a colume mount and cut the cup off it and graffted it to the center of the factory colume cover . Doing it this way The gauge looks nice and centered and is about 1/2" lower than if you used the mount in its original configuration. https://www.dieseltruckresource.com/...cat/500/page/1
Old 06-02-2005, 11:15 PM
99 cummins's Avatar
I mounted my mechanical guage on the cowl coming out of the hood, that way I can watch it as I drive and don't have fuel running into the cab, works great. I put some extra length to the braided line so that when I raise the hood the gauge just goes up with it.
Old 06-02-2005, 11:28 PM
jimjawz's Avatar
chk my gallery for pics. Mine is also on the hood and is a great place for it.
Old 06-02-2005, 11:58 PM
Dr. Evil's Avatar
How long have you had it ouside the truck?? No fogging problems?
Old 06-03-2005, 04:10 PM
Olratlr's Avatar
Gauge
On my 2001 Sports there was a cubby hole like for change
I took it out and put it there.
dodgeguy71
17
01-19-2012 12:52 AM
barngal6
07-05-2009 06:49 PM
Random Acts
12-16-2007 02:04 AM
tswan
03-25-2007 04:14 PM
whitebuffalo
11-03-2006 10:53 AM
Quick Reply: Where to put a fuel pressure gauge?
