purchased comp map not same
Old 06-10-2005, 07:42 PM
pcbing's Avatar
Angry purchased comp map not same
I purchased comp for my 01 HO and did not bother to ask what map plug it had.My truck has smaller plug with 3 round pins and the comp has 3 flat spades. What can I do? I already called EDGE but did not get any help. Mark it up to inexperiance.
Old 06-10-2005, 08:11 PM
duallydave's Avatar
did you purchase it new?if so just return it.if not you can try a wrecker and get the plug you need and slice either the truck or the comp.they may be diferent voltages but edge should be able to anwser that for you.or try posting in the clasifieds here and maybe someone will trade.there was a guy who had a comp for an 01 and wanted to trade it for an 99 style like yours.
Old 06-10-2005, 08:47 PM
dezlsmkr's Avatar
I am nearly positive that with my old comp i got it came with a adapter thet would go into the little circle and adapt it to the flat
Old 06-10-2005, 10:43 PM
pcbing's Avatar
thanks for your help.I need to do something cause it doesnt do much good sitting on the workbench.
Old 06-11-2005, 08:49 AM
duallydave's Avatar
Talking
you can still hook it up,just dont tap thw wire.if you really get into her you may get a boost code.but you can still enjoy it as an ez for now.
Old 06-11-2005, 09:46 AM
pcbing's Avatar
so i can hook it up through the data port only and not worry about the map for know?
Old 06-11-2005, 09:50 AM
PourinDiesel's Avatar
Can you post or email me a picture.
I am still confused on which plugs you are mentioning.
Something doesnt sound right here.
sporter27@comcast.net
Old 06-11-2005, 11:45 AM
pcbing's Avatar
the map sensor on the truck has 3 round terminals in a row not in a triangle instead of 3 flat terminals in a row like on the box. Ill try to borrow a camera a get a picture up.
Old 06-11-2005, 09:34 PM
duallydave's Avatar
i would think it would be ok to hook her up to only the data port,the map sensor only works a s a boost fooler in ez mode.with the wire tapped i think the map sensor plug senses boost to allow diferent fueling depending on your settings on it..try it in ez mode and see if you get anymore power and no codes.
Old 06-11-2005, 10:34 PM
joefarmer's Avatar
The MAP connector pcbing has on his 2001 truck is black, about 1/2" wide with 3 round prongs in a straight row. The comp has white/grey, 1" wide connectors that have flat, 3 spade-type prongs in a row.
I believe the Edge documentation shows the type of connector in the first picture:
http://www.edgeproducts.com/pdf/inst...ons_011305.pdf
OnEdit: Here's the connectors on the COMP (shown from the '02 comp in the classifieds right now):
brandon.
Old 06-12-2005, 01:11 AM
So you have a 2002 (locking map sensor) and need a 2001 harness.
Old 06-12-2005, 10:41 AM
dezlsmkr's Avatar
Like i said i am almost positive that they make an adapter for that my buddy had the same problem and the adapter from edge was 80 $ but maybe you can make your own or find it cheaper. The one he bought came with the adapter he just lost it
Old 06-12-2005, 02:03 PM
DR3500's Avatar
Do not hook it up to just the data port, you have to hook up the map also. it will throw codes and you won't gain anything by running it this way. EDGE should be able to supply the adapter you need, you might have to pay for it but maybe not.
Old 06-12-2005, 02:50 PM
pcbing's Avatar
for what ever reason edge wont sell me one. I bought it used and they do not want to deal with me. I was told to try tst and they might be able to sell me one. I also have a cummins tech looking up the pin ID's for me to see if I could maybe make my own harness.THANKS for all of your help and info. This site is awesome!!
Old 06-14-2005, 12:31 AM
got snow?'s Avatar
I bought the adapters from Bob Wagner. It adapted the smaller plug to the bigger locking one and they weren't 80 bucks either.
Quick Reply: purchased comp map not same
