Pulse tire size adjustment not working??
Old Jan 21, 2009 | 09:20 PM
STACKED's Avatar
Am i not doing something right or what? i have 315s and i understand that its circumference but it doesn't matter what number i put in it doesn't change.
Old Jan 21, 2009 | 09:57 PM
busta's Avatar
there are 2 mph readings if you think you have the right settings in for tire size you might be looking at wrong speed there is actual i think it is and another one
i have mine reading with in 2 mph of speedo that was reset at dodge for my 315/75/16
Old Jan 21, 2009 | 10:00 PM
STACKED's Avatar
yeah im lost i guess, is that some where other than the tire size adjustments?
Old Jan 21, 2009 | 10:13 PM
busta's Avatar
no you set the tires and then the reading for speed on the pulse you have mph and corrected miles per hour sorry had to look at the site
one of them will give you the right speed you are going or at least close to it
Old Jan 21, 2009 | 10:24 PM
STACKED's Avatar
i can change both the numbers and still no change i wonder if i can fix just the spedo with my superchips tuner. would that effect anything
Old Jan 21, 2009 | 11:04 PM
hink's Avatar
1) Set the stock tire size
2) Set the tire size for the tires you are currently running
As busta stated, you can then choose the Actual MPH, which is what the truck is actually reading
OR
Choose Corrected MPH which will be the true speed of the vehicle.
Old Jan 22, 2009 | 12:07 PM
STACKED's Avatar
I changed both stock tire size and current tire size and enter it and thats it i dont see any other option .I guess I'm not seeing that. Is it supposed to be in the same menu
Sleigher
May 4, 2017 02:12 PM
isu elvi
Feb 14, 2009 07:57 PM
Tingram
Oct 12, 2008 11:24 PM
Pinkston
Jul 22, 2008 06:00 PM
Cummins600
Apr 8, 2006 06:24 PM
