PS inter cooler, Which couplings?
Old Mar 9, 2011 | 10:36 PM
Robofig's Avatar
when I install my PS IC, I will need to buy 3" couplings.
Do I need to buy the "hump" style, the ones with the wire rings, or will the straight ones work?
Does it matter?
Old Mar 9, 2011 | 10:58 PM
jimbo486's Avatar
You'll actually need 3.25"-3" reducers as the PS necks measure 3.25". The hump style hoses are typically used when the i/c tubes will be flexing at the joint often and also allow for a little movement for minor adjustments if necessary. So hump hose or straight hose is your choice.
Old Mar 9, 2011 | 11:08 PM
Robofig's Avatar
Does anyone sell 3.25 x 3 inch reducers?
I have not seen any.
Old Mar 9, 2011 | 11:10 PM
jimbo486's Avatar
Silicone Intakes - Intake Pipe Reducers
Old Mar 9, 2011 | 11:12 PM
Robofig's Avatar
Right on! thanks
Old Mar 9, 2011 | 11:14 PM
jimbo486's Avatar
No problem. Where in So Cal are you located? I'm in Cypress between Los Alamitos and Buena Park.
Old Mar 10, 2011 | 08:13 AM
Robofig's Avatar
I'm off the I-10 in Yucaipa
dodgeboy67748
May 2, 2007 10:51 PM
DodgeCowboy
Apr 14, 2007 04:00 PM
slant6racer
Apr 16, 2006 06:59 AM
low c1500
18
Dec 2, 2005 01:05 AM
fozzy777
Nov 1, 2005 02:23 PM
