Pre91.5vs 91.5-93
Old Jul 21, 2005 | 09:00 AM
csramsey640's Avatar
Pre91.5vs 91.5-93
I have been keeping my eye out for a 1st generation, and would like to know what differences the pre91.5 holds to the later 1st gen's. Other than innercooler. which is a better base to start working with?
Also what year did the Getrag come out?
Old Jul 21, 2005 | 09:49 AM
Alec's Avatar
Getrag was in all 1st gen years. Post 91.5 trucks have the "Chevy" style front hubs and brakes. 92 and up have a deeper frame dimension and bigger bolts for the spring bushings on the front. 92's also have the voltage regulator built into the ECM, and a crank sensor (and wiring under the dash for a tach). 92's also reset certain codes for the ABS automatically. The 91.5 to 92.5 trucks have the 21cm turbo housing . I would say get a '92.5 or later, if you have a choice . . .
Old Jul 22, 2005 | 01:11 PM
Truck build date is Sept 25,1991, but listed as a 92 So im guessing it has the 21cm turbo. How much does the 12cm/14cm's go for?
Old Jul 22, 2005 | 01:13 PM
apwatson50's Avatar
12cm cheap to free, 14cm arm and a leg
