Power Window Regulator
Old 01-08-2007, 08:54 PM
thesheriff's Avatar
I found out today that I have to replace the window regulator as a whole unit. This thing is pretty pricey through Dodge($250). Any suggestions one where I can get this unit at a more reasonable price? Also, is there a trick to changing this darn thing? It looks like a chore! Thanks for the help.
Old 01-08-2007, 09:01 PM
yfz450guy's Avatar
you could go used but how much longer would that one last?
not that hard to swap out. get the door panel off the roll the window down to gain access tot he bolts that hold the glass. remove bolts. push the glass up and tape it up at the top. roll regulator so that the arms are paralell. unbolt regulator. remove from door and unplug.
reinstall in reverse.
Old 01-09-2007, 06:22 AM
Greguw's Avatar
There easy to change ... if you can get the window down so you can reach the two glass mount bolts ...Undo them slide the glass up the track and tape the window up , unhook the wires take out the 4 bolts ...Then pull that sucker out !
I'm about to list a power window and lock set-up on here ...I pulled all this stuff out of a truck with under 100 K .
Greg
Old 01-09-2007, 03:51 PM
gorms's Avatar
$250 is way too much. I was pricing out regulators because I left the window down and it rained overnight, wouldn't go up in the mornin. Turned out to be just a jammed up unit, gave the regulator a little assistance while it was out and it worked fine. Anyhow, I got prices from $110-150 from various autopart stores. Try NAPA, or even some of the local guys can get it cheaper than that for sure.
Old 01-09-2007, 07:38 PM
BCB
BCB's Avatar
i replaced just the motor in mine for something like $58 form a local auto parts store. real easy job.
Old 01-09-2007, 07:43 PM
thesheriff's Avatar
Ready to Tackle
Thanks for all of the help! I ordered the whole new unit online for a $100. After looking at it some more, the replacement doesn't seem that bad. But, we will see how my luck goes .
XLR8R
26
01-02-2013 12:15 PM
rebal
01-07-2011 09:42 PM
sdubfid
12-22-2010 10:26 PM
Snapper
09-08-2006 03:59 PM
Quick Reply: Power Window Regulator
