Polishing clear plastic
I'm working on a 77 chevy truck, and the clear plastic gauge cover is hazy. I'd like to clean or polish it out instead of buying a new one. Anybody know anything that would work?
meguires makes a clear plastic polish ....... it works awsome , my dad used it on his helmet visor
http://www.meguiars.com/store_meguia...&subcatagory=1
On a vehicle that old I would guess that the haze is probably on the inside of the plastic, specially if the previous owner was a smoker. To clean it properly would probably entail removing the cover and polishing both sides.
When you finished polishing the plastic go over it with Pledge furniture polish.
If the lens is acrylic DO NOT use a paper towel. You can buy plastic polish at your local small airport, it is used to clean aircraft windshields, it comes in an aresol can. You spray it on then wait for it to dry before buffing it off. Terrycloth works well, paper towels make the problem worse.
The owner was a smoker, and the haze appears to be on both sides. I tried toothpaste without much result, but I suspect that the older kinds would work better, all I had was a gel type. I'll try the parts store today, not many choices here. (no motorcycle stores and airport doesn't even have a store) Thanks for the suggestions.
I got some 3M cleaner and polish from the parts store. It should work good, the counter guy says they mostly sale it to clean the plastic gauge covers and tail lights and it's supposed to work good. I won't be able to use it till this evening. I'l let you all know the results.
Originally posted by erics76
Thanks for the tip. Any specific brand?
"Tarter control" works good for getting that nasty film off too.
