plug for gooseneck trailer
Old 12-15-2009, 10:40 AM
Slice's Avatar
could someone please tell me as i am new to gooseneck trailers,
plan to purchase one shortly what i need to know is there a wiring harness for it. is there one that plugs in underneath and goes to an outlet in the bed or ? do you just plug into the one on the bumper ( I have towing package already)
My other truck ( ford) has a outlet in the bed for a gooseneck but i bought it this way.....
thanks
Old 12-15-2009, 11:24 AM
wmonroe's Avatar
I just run my cord over the tailgate and use the plug on the bumper. They do sell kits though to put a plug in the bed.
Old 12-15-2009, 11:30 AM
Totallyrad's Avatar
If you use the 7 pin RV plug on the trailer it's the same as the factory Dodge plug if you have a trailer tow package. You can plug it into the one in the bumper but you'll need allot of cord if you turn tight to the right. You can get the 'in bed' kit from e-trailer for around $60. IIRC it's a plug and play unit, no splicing required.
Old 12-15-2009, 11:35 PM
With age comes the cage
Colo_River_Ram's Avatar
I installed an in-bed harness, I don't have to worry about the paint or ripping things apart when I jackknife the trailer. It takes less than an hr. to mount it and wire tie the harness into place. All connections are water tight with no cutting / splicing
Link to harness listed in my sig:
http://accessories.etrailer.com/sear...0137&x=42&y=10
Pic of my setup:
Old 12-16-2009, 12:28 AM
RAMRODD's Avatar
Put a plug in the bed.The bumper plug will make a unreliable connection. Basically the factory plug is junk. It was in my 04 and it is in my 06. The better quality plug in works every time.
Old 12-16-2009, 05:56 PM
cLAYH's Avatar
I have my trailer wired so the cord comes off the middle of the neck of the trailer(GN) and goes to the bumper plug on the truck. A rubber bungie takes up the slack and keeps the cord off the tailgate.
wadecool
04-24-2007 10:01 AM
dws35
01-09-2007 01:31 PM
SkyHarborCowboy
10-17-2005 10:13 PM
Dodgezilla
12-07-2004 09:41 PM
Amish hauler
04-08-2004 07:07 PM
Quick Reply: plug for gooseneck trailer
