Please help wouldnt shut off!!!
Old Jul 29, 2007 | 06:15 PM
rootremblay's Avatar
Exclamation Please help wouldnt shut off!!!
Ok I cleaned my K&N lubed it up good with my atv filter oil (spray, very tacky). is it possible the fumes from this after setting for a couple hours kept the truck running( after key was turned off , it ran for 15+- seconds )? I have just washed it again gonna go get the oil thats supposed to be used now. please any help??
Old Jul 29, 2007 | 06:44 PM
volly818's Avatar
how long did you have it running? did it run fine when it was running?If it ran fine when it was running and the spray is made for a gas motor then imo it was not from that
Old Jul 29, 2007 | 06:52 PM
torquefan's Avatar
It's possible that if something flammable is sprayed on the filter it can cause the engine to run for a second or two after shutoff, but I would think if it ran for 15 seconds, as you claim, it is merely coincidence. If there was that much flammable substance in the filter I believe it would have caused an elevated idle right from startup. The first thing I would do is to disconnect the shutoff solenoid rod from the fuel lever on the injector pump and inspect it. I bet the pivot point is rusted and sticky and needs lubrication.
Old Jul 29, 2007 | 06:56 PM
infidel's Avatar
Highly doubt the filter oil caused it.
Usually this a symptom of worn out starter contacts, a $10 item that will burn up your $200 starter solenoid if left be. At 152k they are definitely due.
You can buy heavy duty contacts here http://www.fostertruck.com/dodge/default.htm install is easy.
In the meantime learn where the connector to your shut down solenoid is so that you can disconnect it in event of a run-on. Sticking contacts are known to start fires.
Old Jul 29, 2007 | 07:14 PM
clutch1's Avatar
listen to infidel, its the contacts.
Old Jul 30, 2007 | 01:13 PM
The first time I started it after I put it in it did cause a high idle for half a second as soon as it started, I came inside and got a drink etc.. went back out and started it and shut it right back off and thats when it did it, and It was more around 5 seconds maybe less, sorry I was kinda shook up a little when I wrote the thread ( dont need anymore more problems with my truck ya know )
Old Jul 30, 2007 | 01:14 PM
The starter contacts sound right to me as well infidel, it has been doing the click, click deal for bout a week. I replaced them in my 96 at about the same mileage now that I think about it.
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
cameroneod
16
Oct 5, 2007 12:36 PM
djcheez
Jan 22, 2007 12:29 AM
CASMOKIN
Dec 29, 2006 10:28 AM
