please advice needed A/C passenger side??
Old Jun 19, 2008 | 07:49 AM
joshworthy21's Avatar
This is not for my truck but my buddy has a 2006 mega cab and all the sudden his a/c is acting funky. He says that the drives side vents are blowing just like normal but the passenger side vents are just bearly blowing (but they are still blowing a little bit)n I've done some searching but and have even found post on here that sound similar but nobodys narrowed it down im not sure if its the recirc door, the blend door, or somthing completely different.
Any help would be appreciated its hot riding shotgun in his truck!!!
Old Jun 19, 2008 | 07:53 AM
John Faughn's Avatar
All of the flow is controlled by the blend doors , the blend doors are controlled by vacuum , so use a vacuum gage to see what is the problem , a disconnected vacuum line , loss of vacuum or the diaphragm in the vacuum motor , oh & the switch on the dash can leak or not transfer vacuum .
Old Jun 19, 2008 | 08:11 AM
Hounddog's Avatar
What year forum is this? There is NO VACUMN on 3rd generation trucks heat/ac system controls.Its all electric.There are issues with blend doors and recir doors.Try using the SEARCH function.Ought to be lots of info and reading.
Old Jun 19, 2008 | 09:07 AM
J BODY's Avatar
pretty much disreguard everything John Faughn just posted.
Old Jun 19, 2008 | 09:28 AM
2006Mega's Avatar
i had the same issue with my truck, turned out there was a ground wire that was broken and was not allowing one of the doors (blend or recirculate) to not function properly. took the dealer around 3 hrs or so to fix.
Old Jun 19, 2008 | 09:40 PM
pos dodge's Avatar
ac
I noticed on my 06 that more air comes out of the passenger side now. (yes i know all the plumbing comes from the passenger side to the driver) So now i ride around with both passenger vents closed and still have poor circulation coming out of the drivers side. I have watched the motors move when you turn the **** in each selection. I cant figure out what it is.
Old Jun 20, 2008 | 07:05 PM
anybody else? also just so I can be clear what is the difference between what
the blend door and the recirc door does? thanks!
Old Jun 20, 2008 | 08:43 PM
titoheadfaceman's Avatar
blend door blends warm air and cold air for temp control,
Recirculation, or fresh air door switches from pulling in air from the outside to just recirculating the cabin air. That is usually the difference between Max A/C and Normal A/C
Old Jun 21, 2008 | 02:17 PM
Sittingbull2's Avatar
This is kinda off the subject to an extent but here goes. I had a waterpump bearing go out and slung the serpentine belt off. When it did this I had like no brakes I thought our truck had a pump to make vaccum for the brakes?
Old Jun 21, 2008 | 04:33 PM
Hounddog's Avatar
Run off the back of the power steering pump I think.No belt kills it.
Old Jun 21, 2008 | 06:08 PM
Tree DR's Avatar
Had a friend with the same problem turned out just low on freon. System tries to keep the driver happy. Sometimes it's better to keep the wife happy.
Old Jul 5, 2008 | 11:08 PM
delasem's Avatar
Ok got the same issue...Wife pregnant and unhappy her side blows warm air my ice cold. She even mentioned the words...God i dont dare say!..MINIVAN!!!!. does enyone know where the blend door is so that i can check it..any diagrams, pictures or guides???.
Old Jul 5, 2008 | 11:33 PM
shortbed rv's Avatar
You need to read this thread to understand the problem.
https://www.dieseltruckresource.com/...passenger+side
I had a 15 degree difference between the driver and passenger side and added freon and now there is about a 6 degree difference. I also believe the ac mod thread would help.
Common
Apr 27, 2008 12:47 PM
Adam3291
Oct 31, 2006 11:53 AM
PapaSmurf
Aug 9, 2003 12:12 PM
Carnage
23
Jun 6, 2003 11:48 PM
Tigerfan
Mar 5, 2003 07:53 AM
