p pump conversion
Old 07-02-2010, 12:08 PM
DieselRebel24's Avatar
p pump conversion
i think its time to nut up or shut up and p pump my pickup. anybody out there have any good advice, tips, pros, cons. anything helps.
Old 07-02-2010, 01:02 PM
Silver Ram's Avatar
There was a whole kit for sale in the classifieds. Dunno if it's still there.
Old 07-02-2010, 06:14 PM
graphitecumnz's Avatar
I did the conversion...
Pointers:
Make sure you have a.) enough time set aside or b.) another vehicle you can drive.... the swap is one thing; tuning and working out the bugs are another thing.
Sourcing a conversion kit is the easiest way to make sure you have almost all of the necessary parts but is more expensive than picking and piecing together the parts from junked trucks and other online sources...
Seriously consider a cam swap... this is the absolute best time to do it even if you don't "need" it... the cam is coming out to swap gears anyhow; might as well get a quality aftermarket replacement and it's really not that expensive.
Study up on P7100 tuning that way you understand the adjustments you can make with the AFC and plate position... also make sure you absolutely understand how to time these pumps to the engine... countless forum posts where guys have timed the truck 180 out and they can't figure out what's wrong... or they've rotated the engine incorrectly and have retarded the timing when they thought they had advanced it...
Try and source a 12valve tappet cover and ditch the 24valve puke bottle... chances are you're going to have oil spilling out of there since the P7100 returns it's lube oil right into the front cover where the 24valve breather element is...
Study, study, study... there are no instructions out there to do the swap... you either know what and where things are going or you don't...
Old 07-06-2010, 10:31 PM
graphitecumz, you need to come to montana so you can help me tune it when i do it lol
Old 07-07-2010, 08:24 AM
bigsingle's Avatar
Why are you converting?
If you think its the answer to all your problems then think again.
Old 07-07-2010, 07:00 PM
Tate's Avatar
What a vague statement!
I did my conversion 3 years ago, have never regretted it for a second. Only reason its not in DD duties anymore is because 2wd doesn't perform well in 12"+ of snow with no weight in the back.
Old 07-07-2010, 10:46 PM
cuz vp44 injection pumps are what i would like to call a piece of sh*t.
Old 07-08-2010, 12:08 PM
sure, lets work out a mule deer hunt... I'll bring the 7mm Mag and reach out and touch one...
Old 07-14-2010, 06:31 PM
did you guys buy a conversion kit or did you find all the parts individually?
Old 07-14-2010, 07:32 PM
I bought the conversion kit out of convenience... I had to have the truck torn down and back up and running within days because it was my only vehicle. I couldn't afford to not have some part or piece and be SOL on finding it on a Saturday at 8 pm.
Old 07-15-2010, 03:28 PM
Tate's Avatar
That being said, the conversion kits are far from having everything a guy needs. I still had to source fuel lines, overflow valves, need a new oil line to the vac pump, a new crank seal, and so on. It gives you the big parts that will get you most of the way, but there is a bunch of knick knacky stuff that will have to be sorted out. I had the bulk of the work done in two days. The remaining week and a half was getting the little things that I had to drive an hour each way to get.
Old 07-15-2010, 08:23 PM
scheid diesel had a pretty good lookin kit. comes with fuel lines also. i just found out that the solenoid in my vp44 is shot and that my "new" well one year old pump is shot even though i had a air dog 150 on it from day one. anything you guys can tell me about this conversion would come in handy.
Old 07-16-2010, 03:34 PM
Tate's Avatar
Low pressure fuel lines, I meant. The high pressure lines come in the kit.
Old 07-20-2010, 11:13 PM
what are the little things to be exact
Old 07-21-2010, 06:44 PM
low pressure fuel line, fuel return line, oil feed line, a few gaskets, etc...
Quick Reply: p pump conversion
