p-7100 max inlet pressure
Old 04-04-2009, 01:29 AM
DTanklage's Avatar
how much fuel pressure can you give em?
is output affected by fuel pressure?
thanks in advance
don
Old 04-04-2009, 10:59 PM
65fury's Avatar
Hey Don
Ive talked to some guys about this a while ago, i was told not to run more than 50psi at idle(40psi is probably safer), (60psi can blow seals in the pump) as far as more power from this, there is none, but it helps to raise the pressure (via the return valve spring mod). This helps with keeping from starving the pump of fuel when stomping the go pedal
jason
Old 04-05-2009, 12:01 AM
DTanklage's Avatar
building my own system (with a bypass reg and return) and didnt know what the pump wanted
thinking about setting it up so it only sees 20 at idle and rises proportional to boost
that would be 65 psi of fuel pressure when it maxes out at 45 psi boost
guess that will work fine
thanks
Old 04-05-2009, 02:19 AM
65fury's Avatar
Sweet setup, just be careful..... you'll blow seals in the pump at 60psi my truck ran 45psi at idle and at full throttle it wouldn't drop below 25-30psi, i played with it a bit and never saw a difference in how it ran if the pressure was at 5psi WOT or 30psi WOT. Just as long as it had sufficient pressure it ran great.
Jason
Old 04-05-2009, 04:18 AM
DTanklage's Avatar
oh
well i dont have to boost ref it
can just set it at 40 and be done with it
guess thats what i will do
thanks
Old 04-05-2009, 08:55 PM
Ronco95's Avatar
Don't forget to watch the fuel pressure at the filter too. You can split the canister open easily.
Ronnie
Old 04-05-2009, 11:43 PM
DTanklage's Avatar
thanks, i am not gonna be running the stock filter
napa 3352
its fregin huge
humm, does not say min burst anywheres on it
anyone know what they will take?
been thinking, can set reg up with 5 or 10 psi at idle, boost ref it, and it wont see 60 psi
just under, and that would only be at max boost
unless there is a filter issue thats what i am gonna do
thanks again
don
Old 04-06-2009, 01:11 PM
65fury's Avatar
napa 3352
its fregin huge
thanks again
don
I think your filter will be fine, ive run my truck at 50psi cruising and never had an issue with leaks or blowing the filter, but ive never run it at 60psi so who nows...... that might be the lucky number the filters splits on
Jason
Old 04-07-2009, 12:21 AM
Tate's Avatar
napa 3352
its fregin huge
thanks again
don
Why the boost reference? Its not a FI gasser. Just keep your pressure up at 25 or better.
dochawken
17
10-13-2011 07:03 PM
PourinDiesel
15
06-16-2008 09:51 AM
hopak
09-07-2006 12:38 PM
Ram of Steel
08-29-2006 07:21 AM
tony
01-24-2005 10:16 PM
Quick Reply: p-7100 max inlet pressure
