overhead console
Old 01-21-2009, 09:52 AM
jimmyd's Avatar
overhead console
The mechanic at my Dodge dealership tells me that when my '08 6.7 goes into Regen , the overhead console should read "regen "
I've never seen that nor have I ever seen " catalyst full " on the console.
has anyone else ever seen this ?
Old 01-21-2009, 10:16 AM
coolbreeze's Avatar
I haven't.
Old 01-21-2009, 11:54 AM
chrisminx's Avatar
i have seen it
Old 01-21-2009, 12:32 PM
Dodgezilla's Avatar
There was supposed to be a new flash that updated the trucks to do that but I think there were some big problems with it and it got pulled before hardly any trucks recieved it. There was also supposed to be a sticker attached to the sun visor explaining the whole process too.
The 08 I had never showed this info....
Old 01-21-2009, 02:34 PM
DJENSEN9367's Avatar
I have had mine do it several times. From memory "regeneration in progress"
Regeneration complete etc. There were a couple of other things but can't remember exactly. Had the reflash to the overhead donea year ago and just saw this on mine during the cold weather and slow icy driving.
Old 01-21-2009, 05:27 PM
Tree DR's Avatar
My truck has never said anything other than system ok. My visor has the sticker telling about the diesel exhaust aftertreatment system. I know my truck has done regen a few times.
Old 01-21-2009, 11:17 PM
DarkDesertCTD's Avatar
My truck hasnt ever said anything but System OK and thats OK with me
Old 01-22-2009, 08:29 PM
tnhtractors's Avatar
My 08 overhead one day displayed catalist 70% full. only cus I left it idling for 3 hours one day. Got on highway and drove at highway speed, and it went into regen mode. My truck has been in regen mode many times, you'll know when its in cus it loses power. feels like a power stroke. 62,000 and only been in shop once. EGR valve
Old 01-22-2009, 10:35 PM
1stGen545's Avatar
Nine has never showed it but I know when it starts because of my Edge Attitude
Old 01-23-2009, 10:51 PM
Bill Davis's Avatar
My 08 dinged and the overhead said "catalyst 80%, regeneration required.
I fueled up, dropped it in 4th gear ran up to 65 mph. Three miles later it read
"catalyst 70%, reg. required. About three more miles it dinged and said
regeneration completed. This happened after about three days of slow,
icy driving. That was the first time I ever noticed anything like this.
The turbo was replaced at 11,000 miles and cleaned at 22,000 mi.
I run with the exhaust brake on most of the time and do not pull regularly.
BCD
08 2500 laramie
Old 01-25-2009, 09:34 AM
Diesel fitter's Avatar
I ran mine on a long trip for the first time on Friday and when on the highway at 75mph at about 2100 rpm and speed control set. I noticed the pyro temp go from 1000 to 1300 for about 20 minutes while driving on relatively flat ground. There was no message on the overhead saying that it was in regen but, after about 20 minutes the temp dropped to 1000 and stayed there for the remainder of my 550 mile trip. I am assuming that it was in regen when the temps went up as my speed was steady on flat ground with speed control set when the temp climbed and (after about 20 min) went back down.
Old 02-07-2009, 08:51 PM
dirtball08's Avatar
Thumbs up
Yep had it happen once. Checked the manual, drove it at what it said would not go away. Took to dealer, and they did the ecm update at 14000km and no problems since, knock on wood.
Old 02-07-2009, 09:33 PM
dj88382000's Avatar
the 6.7 will not go into a regen with the cruise control set
Old 02-08-2009, 01:05 AM
Not true, I know mine went into regen with the cruise on at 75 mph @ 2100 rpm. My pyro jumped up from a steady 900 degrees to 1300 degrees for about 20 minutes. That was obviously a regen cycle.
Old 02-08-2009, 06:57 AM
Como4076's Avatar
I have had my truck now for 1 year and 14,300 miles later I have never seen any message except for " Oil Change Required See Dealer" that is it !!! Other than that it always says " System Ok"
Quick Reply: overhead console
