Sponsored by: CARiD
Optima blue top batteries
Old Apr 25, 2006 | 12:23 AM
powerstrokin03's Avatar
I have 2 optima blue top batteries which are the deep cycle versions. I used to use them in my race car, and now i have no more use for them. Would there be any damage done if i were to put them in my truck in place of the factory batteries? Not sure what the alternator would do to a deep cycle battery if anything. Thanks guys.
Old Apr 25, 2006 | 05:48 AM
DetroitDiesel71's Avatar
From: Dayton, NJ (temporarily while In USCG on Staten Island)
From what I have been told you can drop any series of the optimas in and be fine. Sizing for fit is the only issue. I am about to buy the reds.
Old Apr 25, 2006 | 05:58 AM
HOHN's Avatar
Yellows and Blues are identical-- Red tops are a little different.
Any will work just fine in our application. Red work better in most gassers, but your intake heaters draw enough juice to make a deep cycle not panic.
jh
Old Apr 25, 2006 | 11:32 AM
Ok thats all i needed to know, thanks guys.
Old Apr 25, 2006 | 11:38 AM
ptgarcia's Avatar
Are the blues the true deep cycle battery? If I'm not mistaken, deep cycles are not designed for high current draws like those from engine starters. I'm not 100% on this so please correct me if I'm wrong.
Old Apr 25, 2006 | 11:40 AM
Yes the blue tops are deep cycle batteries.
Old Apr 25, 2006 | 12:50 PM
SoTexRattler's Avatar
Not true... The Blue ones are just marketed for marine use. They make a blue starting battery and a blue deep cycle battery. Same thing with Yellow tops. Check it out...
But the Red tops only come in starting batteries...
K.
Old Apr 25, 2006 | 01:09 PM
durasmack's Avatar
mine are blue and they work just fine.
Old Apr 25, 2006 | 01:55 PM
bnold's Avatar
I have a blue in my boat and I think it puts out something like 1150 cranking amps
Old Apr 25, 2006 | 04:28 PM
I thought the same thing but I learned otherwise. THeir marketing people have the public confused about their product colors.
Their actual part numbers differ between a blue marine DeepCycle and a blue marine starting batt. Notice the "D" in the deep cycle batt part numbers, and the lack of the "D" in the SLI batt of the same group size.
They do offer a bewildering array of terminal configurations for both type of batteries regardless of top color.
Take a look at the actual life spec's for each type of battery, deep cycle-vs-SLI. Specifically, observe the cycle life of each type of battery when deep cycled... 50 -vs- 350 cycles! There is a BIG difference.
http://www.1st-optima-batteries.com/
K.
Old Apr 25, 2006 | 05:27 PM
Willy91's Avatar
I've got blues and they've workied fine so far.
Big Green11
Sep 15, 2011 07:17 AM
smokinram99
Dec 25, 2008 11:25 PM
dieselcarpenter
Nov 17, 2007 07:02 PM
perk
0
May 24, 2004 01:26 PM
Stamey
13
Jul 6, 2003 11:03 AM
