Ok, trashed my H1C...Is there a cross reference for turbos?
Old Feb 21, 2007 | 10:34 AM
eyoung429's Avatar
I would like to get a replacement for my H1C....but I want it to be bolt-in...Does anyone have a listing of what will bolt in place for the 91.5 IC 5.9? Ie...found several Garret, couple of Holset's, etc......
Thanks!
Old Feb 21, 2007 | 11:03 AM
JD730's Avatar
HX-35 or WH1C or another H1C. You can use your exhaust housing over (probably the 21cm lag master, so you'll probably want to get rid of that door stop for a better option) or if its trashed you can use the wastegated housing that would come on a stock hx-35 or WH1C, to do that you'll have to move the down pipe back about an inch (I cut an inch out of mine).
Check out http://www.htturbo.com/ if your looking for new.
Old Feb 21, 2007 | 06:44 PM
ChrisLib's Avatar
What JD730 said, or... I picked up a Dodgezilla, makes nice cool boost for my ride, spools fast and sounds awesome (the noise is a side benefit ).
Old Feb 22, 2007 | 03:51 AM
TexasHardcore's Avatar
How is your H1C trashed?
Old Feb 22, 2007 | 07:55 AM
eyoung429's Avatar
air filter collapsed sending a lot through the impeller ... here's the aftermath.
see the nice shiney ring around the impeller? I have a LOT of clearance now!!!
Old Feb 22, 2007 | 11:14 AM
mhuppertz's Avatar
Get the HTT Stage IV 16cm, it's just a little more than a stocker, but WOWEEE!
Old Feb 22, 2007 | 11:35 AM
eyoung429's Avatar
Will have to try one later...budget won't allow it...
I am trying to find something under $300 to get me by for a couple of months.
Old Feb 22, 2007 | 11:50 AM
Micaiahfied's Avatar
eyoung429- look around and see if you can find a used hx-35. they can be had for less than $300. look in the classifieds here. you could possibly get a used h1c for very cheap but the hx-35 would be a nice upgrade.
Old Feb 22, 2007 | 11:56 AM
mhuppertz's Avatar
Or drive the pig for another month and save up another $300 and get a Stage IV!
Old Feb 22, 2007 | 01:04 PM
Find a stock HX35 to get you by for now. junkyards have em for $100 ready to bolt on.
Old Feb 22, 2007 | 02:07 PM
bgilbert's Avatar
That's those cheap j/y's that are nice to ya. I can't get them for less than $200 locally.
chugger
Nov 19, 2009 04:45 PM
horsinaround
Mar 3, 2009 04:33 AM
kokalit
0
May 26, 2008 12:12 AM
mhuppertz
Jan 14, 2008 08:06 AM
BearKiller
Mar 25, 2007 05:31 AM
