Oil??
Old 11-29-2006, 09:17 AM
JonnysDodge's Avatar
Oil??
what kind of Oil do I run in my truck? I have heard that some trucks use certain oil and was wondering if mine does or not? Please help.
Old 11-29-2006, 10:25 AM
plow's Avatar
I use mobile delvac 1300 15w40 but there are countless others just make sure its diesel rated 15w40 weight. If your asking if there is a certain oil that goes in that particuliar engine then no its whatever you prefer as long as its rated for diesel engines 15w40 is the most common weight.
Old 11-29-2006, 12:40 PM
Troutstrannysvc's Avatar
I run rotelli 15w40
Old 11-29-2006, 12:43 PM
bnold's Avatar
Originally Posted by Troutstrannysvc
I run rotelli 15w40
ditto... 10 char limit
Old 11-29-2006, 01:06 PM
Scramblinman's Avatar
I began using Rotella T synthetic 5w-40 in my truck after purchasing it.
Old 11-29-2006, 01:34 PM
TIMMY22's Avatar
rottella T 15W40
Old 11-29-2006, 02:07 PM
displacedtexan's Avatar
I guess I am the disenter, Valvoliene Premium Blue 15w-40, I pick it up at Cummins when I get my Fleetgaurd Stratapore, less than $50 for the oil change.
Old 11-29-2006, 03:56 PM
DieselDaze's Avatar
Chevron Delo 400.
Old 11-29-2006, 04:06 PM
As you can see we use a variety of oils, based on preferance, and avallibility... So you should pick a favorite, and then you can cast a vote next time the question comes up
One thing I should have mentioned in my first post is not to mix oils, as their additive packages may not be compatiable. (if you need to add some in between oil changes)
Old 11-29-2006, 10:58 PM
garretch's Avatar
anyone use the rotella 'low-ash' oil yet? i think it's a "cp-i" or "cp-j" or "cj-p" or something. i was reading the article in diesel power mag a couple months back on low-sulpher diesel. it sez this new type of oil greatly reduces the soot and particles in the oil.
i use schafers with molly...delo if'n i don't have schafers
Old 11-29-2006, 11:14 PM
Cowboy_Customs's Avatar
I havent heard about that oil yet, im assuming this is for the new ULSD engines? Im using AMSOIL pure synthetic 15W-40, and Lucas stabilizer in mine.
Old 11-29-2006, 11:35 PM
superstreet's Avatar
Amsoil 15-40
Old 12-01-2006, 12:29 AM
Fueling around's Avatar
Originally Posted by garretch
anyone use the rotella 'low-ash' oil yet? ...
Probably the newly licensed API CJ-4 oil. Anyone running a pre 07 engine should stay with CI-4 oils. Once you compare the pricing you'll se the first reason. Second reason is that you gain NO benefit running the CJ-4 oil.
Back to original question.
I run Delvac 1 5W-40 synthetic. The reason is mainly for winter cold starting plus I run extended drain.
Old 12-01-2006, 12:37 AM
So will they continue to make the CI-4 as well, or will the new CJ-4 superseed it?
Old 12-01-2006, 04:53 PM
I was told by our Chevron distributor CI-4 oils will be available for a few years.
-John
Quick Reply: Oil??
