I now have a Puck!
Old 06-12-2007, 09:28 AM
Rollin' Smoke's Avatar
Smile I now have a Puck!
the wife just called me and said that fedex delivered my Power Puck a few minutes ago. i just ordered it yesterday right before lunch time. bad part is i am at work and I hate when i have parts at the house to put on but cant get right to it.
still have to get my boost fooler tough........i already have the boost elbow......
question for some of you guys, will the engine defuel if i dont have the fooler on there?
Old 06-12-2007, 10:09 AM
duallydave's Avatar
what boost do you see now?if you see over 30ish with the puck it may defuel,i cant believe diablo doesnt make one or have it built in to the puck.i love the products they make but they need to get on the bandwagon and do boost fooling and get rid of the silly serial port on the predator,so old school,whats next upgrades sent on 8 track tape hahaha
Old 06-12-2007, 10:15 AM
yea i definately agree they need to get it together on the boost fooling thing.
right now I see 27, alomost 28 psi with only the boost elbow. when i get home later I will put the puck on the truck and see what happens to my boost numbers!
at what point (psi) will the computer defuel the truck, anyone know?
Old 06-12-2007, 10:21 AM
duallydave's Avatar
on my 2nd gen my wastgate was set at 26 psi so it would defuel after that with no boost fooler,i dont know what the 3rd gens wastgate is set at,ive read 29psi but that may be wrong,but im sure if you see over 30ish with the puck it may defuell,you will feel it though.
Old 06-12-2007, 12:34 PM
ropnjessi's Avatar
With my puc on my 03, I hit 28 psi.
Old 06-12-2007, 12:45 PM
gator6's Avatar
Boost fooler
I am not sure but i thought that 03's did not need a boost fooler, only 04.5 and newer.
Old 06-12-2007, 12:57 PM
well I am not sure either, basically why I asked the experts!
but I went home at lunch time and installed the puck. it was so easy and only took about 3 mins. to do. man what a difference it made in the driveablility of the truck. took it on a test run really quick before i had to get back to work. I was rolling along about 55-60 mph and laid into it hard, she kick down a gear and took off. ran it up to about 75mph and the boost hit 35psi. truck has much more low range power than before and I am very happy with the performance it provides for the price. you just cant beat it when your not wanting to completely BOMB your truck.
Old 06-12-2007, 03:24 PM
hilclmr2's Avatar
When it sets a code for boost(map) to high it will defuel.Do you have the Diablo downloader? Or just the Puck? The Puck is pressure only and will work fine forever, but having something that does duration and timing will be where you get some mileage. Strongly recommend a Billet Flexplate, trust me on that one!
Old 06-12-2007, 03:29 PM
no i do not have the downloader, just the puck. i have had the overboost code before i even had the puck on the truck. this was when i had just the elbow
whats up with the billet flexplate?
Old 06-12-2007, 10:33 PM
hilclmr2's Avatar
Very weak point in the auto's. Just a friendly reminder, as they like to break when these trucks are turned up.
Old 06-13-2007, 10:03 AM
yea I think we all know about the auto tranny's in these things. dont plan on putting big power down. just wanted a little something extra. thanks again for the heads up
update: last night I got to play around with it a little bit. the boost got up to 38psi at one point. I never thought it would get that high without the fooler
Old 06-13-2007, 12:10 PM
CReed's Avatar
No boost fooler needed for 03-04.5s they are manually wastegated. In 05 is when they started adding electronic wastegates to the turbos.
Old 06-13-2007, 12:47 PM
but if I want to eliminate the over boost code then I will need to get a the fooler, right?
Old 06-13-2007, 01:19 PM
CReed's Avatar
You would have nowhere to plug it in at the boost fooler such as the one quadzilla sales will not have anywhere to plug into on your truck b/c it is manual actuated wastegate. Now if it where a 05 or newere then all you would do would be to plug it inline in the wiring harnes going to the turbo wastegate. If you want to elimate the overboost code you will throw then get a box that does boost fooling and get rid of the puck sorry to say it.
Old 06-13-2007, 01:27 PM
DTR 1st Sergeant
soulezoo's Avatar
Not an expert on the issue, but my understanding was that when the map sensor read overboost, the ecm would defuel (on mechanical wastegates) in addition to the wastegate opening. On the electronic versions, it would just open the wastegate.
Maybe I didn't write that correctly-- it seems to me the same thing happens, it just happens in a different way (mechanical vs electrical)
Quick Reply: I now have a Puck!
