not sure about my edge and a-2 setup
ok i got all my stuff hooked up
the edge juice and a-2 and i guess it works ok
i really dont notice a huge difference in power but i only run it in the mileage setting or the tow with the trailer
on tow with the camper( towed it yesterday for the first time with the edge)i wads really disappointed in the way it preformed it was almost like the edge was not even there
can i run it in a higher setting for tow like maybe 3 with is like drive but i am not happy with the tow performance in the tow mode why even have the thing
the a-2 is nice with all gauges in one spot but i already have a nav system in my truck so i could get by with a some piller gauges and/or a smaller monitor
the back up cam is nice but i cal also plug that into my existing nav system and have a 7 inch screen to look at
i have it all hooked as instructed and all guages and settings seem to be working as best as i can tell without some sort of testing
It may be due to the missing information, no one knows how to respond. What year truck, transmission do you have. What other mods do you have? What do you have low boost set to? What are you comparing it to for performance, seat of pants or time? Is it defueling due to the way you have the limits set???
Lots more information needed to have constructive comments. I do not have an A2 but the Juice is what makes it go and I am happy with the performance on mine, both mpg improvement, protection function and seat of the pants response when turned up a couple of notches.
Also keep in mind that you won't notice any difference until your engine warms up. I don't believe it starts fueling before the engine reaches safe operating temperatures. I noticed that when I pulled out of the shop once it was installed. Once I was up to speed, however, I started noticing it quite a bit more when I hit stage 3. You can certainly tell a difference if you adjust it back to stock after driving for a couple days on stage 3.
Thomas
Thomas
Yep the edge will not release any power untill the engine temp is above 162 I believe. You wont really feel a big notice in the power untill you are on level 3If you drive it around for a few days then turn it off you will notice the difference. It all depends on how big of a load you have. I would stay away from level 3 if you are towing more that 4-5000 pounds, anything above that stay in 1 or 2. Even with 4-5000 pounds on level 3 be carful of the right foot.
FirstGen1991
12-22-2012 04:24 PM
Mike L
33
08-09-2010 11:30 AM
Turbo-Dodge
08-02-2008 12:06 PM
